L-series AC compressor
  • L-series AC compressor
    In a typical fashion, the AC comp in my mothers 02 weakotec L-series seized up. The clutch itself cannot be spun by hand. The pulley also seized. Thankfully I had left a compressor bypass sized belt in that car for such the occasion - this is not the first time the AC system fucked up. (last time was the clutch). Anyhow - I know to replace the dryer and the expansion valve, is this unheard of for those cars? Comments are welcome.
    I've never had to do it, so I can't say for all L's, I've only had one problem with the a/c and it was the condenser.
      Just for a verification, you can spin the AC compressor by hand (not the pulley, but the clutch part)?
      I can on the S-series, and I doubt the L-series is much different, just want to make sure.
      Also I am curious if the condenser can be flushed out successfully, or if its better off being replaced. Im hoping some of those guys that worked at stealerships will get in here.
        I am interested, as my A/C isn't working in both my L or my SC.
        And it's getting warmer outside...
        - Sixthsphere Admin Team -
          Going to go ahead and order a new compressor, drier, valve, and orings.
            You use a/c up there?
              Has anyone ever flushed the evap and or condenser on an l-series? I am doing this with as much of the ac disconnected (no comp drier or exp valve). Looks like Acetone is a good (but dangerous ) solvent, as it apparently does not leave a residue and evaporates.
                a/c flush machines use the refrigerant (r-134) in liquid form to "flush" out the lines.
                I would not use acetone.
                PS: 3.0's are stupid..put a 3.6 turbo in it and call it a day ( or years).
                  Yea so fuck L-series expansion valve
                  hurr lets hide it inside the fucknig firewall where you cant access it . fucking bitchass GM influence. disgusting.
                  also this lseries is 2.2
                    Well, we got the ol girl fixed.
                      I was searching for something unrelated and came across this post. the L series in question is still alive and well. I barely remember working on it ... anyway, the AC DOES still work. although even though the AC system seems leak out once in a while. for the life of me I cannot remember replacing the O-rings (i hope we did). anyway, the car itself runs and drives great. i think its almost to 300k miles. missing / damaged B and C pillar appliques of course.
