How to remove an engine without a hoist
  • How to remove an engine without a hoist
    Resulted in
    #beigewatch will hopefully end up in there this weekend hahahahah
    I will take this down when it runs hahaha
      Hahahaha
      2002 sl2 auto
        ahahahahahahahahahahahahahahahahahahahahahahahahah ahahahahahahahahahahahahahahahahahahahahahahahahah ahahahahahahahahahahahahahahahahahahahahahahahahah ahahahahahahahahahahahahahahahahahahahahahahahahah ahahahahahahahahahahahahahahahahahahahahahahahahah ahahahahahahahahahahahahahahahahahahahahahahahahah ahahahahahahahahahahahahahahahahahahahahahahahahah ahahahahahahahahahahahahahahahahahahahahahahahahah ahahahahahahahahahahahahahahahahahahahahahahahahah ahahahahahahahahahahahahahahahahahahahahahahahahah ahahahahahahahahahahahahahahahahahahahahahahahahah ahahahahahahahahahahahahahahahahahahahahahahahahah ahahahahahahahahahaha
          Seems shady.
          I took my engine out once with no hoist in my parent's driveway. I pretty much took it down to the block and the crank and just lifted the block/crank out, rested it on the upper radiator support, then climbed out of the engine bay and took the block/crank off the upper support.
            Also I think that picture is actually of Jackal's car, the picture was just pulled off google images IIRC
              You just need a fork lift or a small backhoe and a big chain lol
                Yus
                - Sixthsphere Admin Team -
                  You could always go back to the truck/tree/chain method Tony.
                  Originally posted by alexofnazareth
                  Do the world a favor and get back to your cornholing.
                    And almost fucking die again from a swinging engine? No thanks haha
                      That is nothin... Me and my boys in action:
                      https://www.youtube.com/watch?v=te48...e_gdata_player
                        Tim Chris and I pulled one out for his coupe at the yard, lift the car off of the entire subframe/powertrain assembly lol
                        99' SL2- stick swapped, static, slammed, DD, forever in progress.
                          It was quite effective
                          -Schaffer
                          01 Sc2 "Zen"
                          14 Wrangler "ManillaZilla"
                          01 Sc2 "Diva" (wifes)
