Definitely a n00b question, right? I did the requisite searching but couldn't find the answer for my case.
I'm ready to install my non-GSi TB. There are four vacuum ports on the bottom, two large and two small.
I plan to cap the two large ports and connect one of the smaller ports to the canister purge solenoid.
My question is in regards to my AIR system. May I safely connect that to the other small port on the non-GSi TB or would I throw codes or create rough running conditions?
I ask because in my searching I've read that where you pull vacuum from (before or after the butterfly) affects engine performance.
