As-bought
$1,000
'99 SC2 - 3 door
Gold exterior with stock spoiler
Tan cloth interior
No evidence of any bad wrecks, but some evidence of minor dings (spiderwebbed paint on rear bumper, etc).
Stock alloy wheels
Automatic transmission (no reverse)
Non-ABS brakes
AC
Cruise
Tape deck with EQ
front speakers blown, rear speakers Sony junk
Tan interior with some burn marks and tears in fabric (seats and headliner), not bad, but not great
Carpet was "crunchy" from mildew, there apparently had been water in the car at some point, and there was evidence of broken glass, probably the passenger door window. Found a small hole in the passenger floorboard, apparently a drain hole for the water.
Mod list:
Mechanical/Drivetrain
Automatic to manual transmission swap with welded differential pin ~$450 (winter '06-'07)
2nd gen DOHC with SCAT rods, hyper pistons, and ported head (added mid '09)
MOS short shifter with stock leather shift knob ~$45(summer '07)
AEM CAI (added fall '07)
SpeedRemedy all-aluminum radiator (added late '07)
Groundpounder TAM (added 9/08 )
Air compressor moisture filter catch can on PCV system (added ?)
Exhaust
Custom 2.5" mandrel bend exhaust system (added mid '09)
91-92 header & downpipe (added mid '09)
new flexpipe (added mid '09)
extra O2 sensor bung (added mid '09)
high flow cat (Magnaflow) (added mid '09)
23" resonator (Magnaflow) (added mid '09)
Thrush Turbo muffler (added mid '09)
Stainless tip (added mid '09)
Stock routing (added mid '09)
Wheels & Tires
15" Aftermarket split 6 spoke wheels (unsure of kind) [for daily driving] $50 (spring '07)
Falken Ziex ZE-512 205/50/15 All-Season tires [for daily driving]
Spun SPK-9 "Web" wheels, 16X7, 17.2lb, white [for autox] $325 (4/09)
Braking
Hawk front brake pads (added 5/08 )
Rear disk swap (EverWear Gold pads)(added 5/08 )
Goodridge stainless brake lines (added 5/08 )
Suspension
(Removed) E-bay front strut bar (added sometime in '07)
AMR front strut bar (added 5/15 )
Twistec rear strut bar (added 5/08 )
H&R Sport lowering springs (added 5/08 )
KYB Struts (added 5/08 )
RPM 17.5mm adjustable rear swaybar and FunkyMonkey endlinks (added 5/08 )
Rebuilt front suspension (winter '11-'12)
- Control arms
- Tie rod ends (Moog)
- Wheel bearings
- Hub
- Sandblasted & Painted knuckles
- Energy Suspension Poly bushings (sway bar)
Audio
Alpine head unit with CD / USB / Aux / Bluetooth / Microphone (added 5/15)
Upgraded speakers - Sony XPlod rear 6.5" (added ?), salvage yard aftermarket front 6.5" speakers (added ?)
Interior
Overhead console with CD storage, sunglasses storage, operational Homelink, space for a couple aftermarket gauges, and map lights that function as the dome light (added fall '07)
Passenger seat adjustable lumbar support (added summer '07)
Rear view mirror with map lights (added sometime in '07)
Leather steering wheel (stock) (added fall '07)
Leather e-brake handle (stock) (added 9/08 )
Full black interior swap (added 10/08 )
Custom black headliner shaped to fit overhead console (added 11/08 )
Custom black interior trim above beltline (added 11/08 )
Custom shifter plate instead of shift boot (added fall '07)
Exterior
Clear corner lights (added sometime in '07)
Corner light turn signal mod (added 9/08 ) - with amber LED corner light / turn signal bulb (added 5/15)
Hidden antenna mod (added fall '08 )
$1,000
'99 SC2 - 3 door
Tan cloth interior
Stock alloy wheels
Non-ABS brakes
AC
Cruise
Tape deck with EQ
Mod list:
Exhaust
Wheels & Tires
Braking
Suspension
- Control arms
- Wheel bearings
- Hub
Audio
Interior
Exterior
