No power to pink wire on ICM 94 S series wagon
  • No power to pink wire on ICM 94 S series wagon
    First off sorry this is my first time posting on a forum. So I bought this 94 S series (dirt track racecar) and it was driven into the garage where it sat for 3 years, So I got it home and started cleaning things up and tried starting it and it has no spark on the coil towers. I checked the pink wire for the 12volts and has nothing, I checked all fuses and they are good. Just wanted to see if anyone had suggestions on where to start?
    I'd start with the 30A fuses under the hood. Also check the main relay by the passenger's feet make sure it's not stuck. Might try swapping those around.
      Yeah the 30amp fuses were good. I swapped the relay inside with one from my other Saturn and still nothing.
