saturnrearcontrolarmsred.jpg hey guys! here is a pic of the rear control arm set. these have 5/8-18 left and right hand threads for easy adjustability. jamnuts lock them securely in place. ends are stainless steel. bushings are Energy Suspension polyurethane. choice of red or black bushings. not pictured, but included, is the rear trailing arm bushings. shown above are the red anodized aluminum arms. base price is $240 shipped. available options at no additional charge, shown below, are plain steel, plain aluminum, and a gold plated steel. also available in chromoly for an additional $25. any other powder coating, painting, or anodizing would be additional and require some lead time. payments can be sent via paypal to [email protected] be sure to include your color and bar style options as well as your shipping address. any questions or to get other paint option quotes, email us at that same address. plain steel tie rod.jpgplain aluminum tie rod.jpgswaged steel gold tie rod.jpg
Rear camber/toe adjustable control arms
What is the weight compared to the stock arms?
Damn...those things are pretty!!! No chance you having a pic of these installed yet is there?
The Site ---> http://gyrlspeedracingteam.com
Buy something dammit ---> http://gyrlspeedracingteam.com/shop
***Secretly wants a VW R32***
Originally posted by Ludicrous Speed View Postthey are about 4.5 lbs lighter for the red aluminum ones. not sure about the steel or unfinished aluminum, as those pieces are currently on their way to me via ups, so i cant weight them.
Originally posted by GyrlSpeedRT View PostDamn...those things are pretty!!! No chance you having a pic of these installed yet is there?
Originally posted by Ludicrous Speed View Postno pics of them installed yet, since nobody has bought them yet. which, i hate to say, is most of the reason almost nobody makes anything for saturns, people want stuff, but dont actually seem to buy stuff.
As I said in the other thread, make me a bumper-beam trailer hitch, and I'll be the first the first person to buy it
Originally posted by siris View PostAre these the same length as the stock arms or longer?
What I was wondering is if the rear track can be extended by .5 of an inch, to eliminate the need for hub spacers to get the rear tires in line with the fronts.
To be more clear, I understand they are adjustable, just wondering by how much.72 Charger: pissed me off, on jackstands.
Originally posted by siris View PostWhat I was wondering is if the rear track can be extended by .5 of an inch, to eliminate the need for hub spacers to get the rear tires in line with the fronts.
yes, you could adjust them out that far, but it would just put the bottom out that far, not the top, and your camber would be a little overboard. id have to do some math to figure out exactly what that would do to your camber, but id bet it would put you outside the camber you would want.
