My brake pedal has a long travel to engage the brakes. I replaced the master cylinder. Brake pads. Rotors. Braided brake lines. ...
  • My brake pedal has a long travel to engage the brakes. I replaced the master cylinder. Brake pads. Rotors. Braided brake lines. ...
    My brake pedal has a long travel to engage the brakes. I replaced the master cylinder. Brake pads. Rotors. Braided brake lines. Calipers. Brake bleed. I think it is the brake booster. I also hear a hiss when i press the brakes. If i need a new brake booster. This is for a 2002 sl2 abs. Will 2nd gen abs brake booster work?
    (Feed generated with FetchRSS)
    More...
