Okay guys im frustrated at the moment the my sc2. Had a leak of oil coming out of what seemed to be the bell housing. So I replaced the rear main seal and still had a leak. I then removed the oil pan and put a gasket on it. Still have a leak. Looks to be coming from either the oil pan still or somewhere behind the fly wheel from above. What do I need to do? And has anyone else had this problem?
  • Okay guys im frustrated at the moment the my sc2. Had a leak of oil coming out of what seemed to be the bell housing. So I replaced the rear main seal and still had a leak. I then removed the oil pan and put a gasket on it. Still have a leak. Looks to be coming from either the oil pan still or somewhere behind the fly wheel from above. What do I need to do? And has anyone else had this problem?
    (Feed generated with FetchRSS)
    More...
    Get a flashlight and from the passenger side look down between the 1 and 2nd intake ports and you should see the Oil Pressure Sensor Switch. if it is oily there change it.
    https://www.youtube.com/watch?v=7Fzq6t6A9FM
    2002 Saturn SC1, Metallic Orange , L24 EFI 1.9 , 208,498 miles
