I need help. Now i have this problem. I have changed the cps witch is standard ignition. Icm brand...
  • I need help. Now i have this problem. I have changed the cps witch is standard ignition. Icm brand...
    I need help. Now i have this problem. I have changed the cps witch is standard ignition. Icm brand name standard ignition new coil packs wutch are master pro ignition, temperature block sensor air temperature sensor the fuel pump witch is a quantum 255 lph. This has been getting worce sence the i had the cps problem. My compression ratio is cyl #1 205 cyl #2 205 cyl#3 206# cyl #4 205. O2 is a denso its been changed as well. I need some help and im nig throwing a code. I was throwing a high circuit bank 1 that goes on and off now it's not going on I'm a little lost
    More...
