Installing trans axle seals
  • Installing trans axle seals
    I am getting ready to put in my new engine and the last step on the transaxle is installing the new axle seals. how do you get these in without breaking or bending? i dont have a lathe to make the perfect tool to hammer them in with. i just damaged one trying to use PVC from the hardware store.
    A piece of pipe that fits, or a seal installer tool. You can usually rent the tool for the parts store for a reasonable amount.
      Fumble through the tail pipe reducers / joiners at the parts store and find a nice fit, weld a plate on the end and tada!
      87 Fiero: Long term project.
      00 sl2: cheap DD pls no mods.
      01 sc2: high comp build round 2.
      08 lmm: aux tank, custom alum tonneau, aux oil cooler, aux filters, plow
      18 Acadia: Family hauler.
        This, but don't even need to weld a piece on the end. Just stick something on it. I also have a bearing remover/installer I use.
          Old thread but thought I'd share my solution FFR. I came up with a creative way to drive in the seal. I had a roll of flashing, and cut a length of it. Rolled it tight, so the ID just fit over the seal and then taped the roll tight. Worked great.
          '99 SL2, 5SP bought new
          Rebuilt at 204,067 September 2017
          Engine, subframe, diff pin mod, brake lines, headliner, alternator, and so on!
          '98 SC2, 5SP bought 2018
