Things I've read but havent had the time to try it on my turd. Its a rule of thumb for every 100 HP you go one step colder and the bigger the gap the better, but with boosted cars it can blow out too much of a gap. (???) I've been running BKR7-11 NGK V-power for a while now with a .30 gap and i was fouling out plugs after 10K miles. So i figured the Iridium would help and so did the shops around here and hey guess what everyone is wrong. Im contemplating going even colder to a BKR8-11 or indexing the plug but I've never really payed attention to the direction of the plug gap. Now I must have over read the story on gapping i pulled this from NGK website...
Since the gap size has a direct affect on the spark plug's tip temperature
and on the voltage necessary to ionize (light) the air/fuel mixture, careful attention is required. While it is a popular misconception that plugs are pre-gapped from the factory, the fact remains that the gap must be adjusted for the vehicle that the spark plug is intended for. Those with modified engines must remember that a modified engine with higher compression or forced induction will typically require a smaller gap settings (to ensure ignitability
in these denser air/fuel mixtures). As a rule, the more power you are making, the smaller the gap you will need.
A spark plug's voltage requirement is directly proportionate to the gap size. The larger the gap, the more voltage is needed to bridge the gap. Most experienced tuners know that opening gaps up to present a larger spark to the air/fuel mixture maximizes burn efficiency. It is for this reason that most racers add high power ignition systems. The added power allows them to open the gap yet still provide a strong spark.
With this mind, many think the larger the gap the better. In fact, some aftermarket ignition systems boast that their systems can tolerate gaps that are extreme. Be wary of such claims. In most cases, the largest gap you can run may still be smaller than you think (pulled from: http://www.ngksparkplugs.com/techinf...stallation.asp.
I'm looking for more success stories so i can figure out my plug problems and help out others with this constant question. Monstah said once that the stock Ignition system can handle upwards of 400WHP IIRC. I know one thing im dumping the Iridium unless I'm using them improperly.
