S-Series Torque Specifications and Service Limits.
This topic is closed.
This is a sticky topic.
  • S-Series Torque Specifications and Service Limits.
    See Below
    2002 Saturn SL1 - RHD
    Re: Service Limit Article?
    3rd gen S series
    Design Specifications (SOHC [L24]/DOHC [LL0]) ITEM
    SPECIFICATIONS
    SPECIFICATIONS
    Type -- SOHC (L24)
    Water Cooled -- 4 Cycle SOHC
    Type -- DOHC (LL0)
    Water Cooled -- 4 Cycle DOHC
    Cylinder Arrangement
    4 Cycle Inline, Transverse
    Bore and Stroke
    82.0 mm x 90.0 mm
    (3.2 in. x 3.5 in.)
    Compression Ratio
    SOHC (L24) - 9.3:1
    DOHC (LL0) - 9.5:1
    Displacement
    1.9 liter (116 cu. in.)
    Valve Train -- SOHC (L24)
    2 Valves Per Cylinder -- SOHC
    Valve Train -- DOHC (LL0)
    4 Valves Per Cylinder -- DOHC
    Lubrication System
    Pressure Feed
    Fuel System
    Unleaded Grade Gasoline,
    87 Octane (R+M) Divided by 2
    Engine Net Weight
    (No accessories)
    SOHC (L24)
    DOHC (LL0)
    89.223 kg 196.74 lb.
    99.872 kg 220.22 lb.
    Engine Block (SOHC[L24]/DOHC[LL0]) MEASUREMENT
    STANDARD
    SERVICE LIMIT
    METRIC
    ENGLISH
    METRIC
    ENGLISH
    Cylinder Block
    Top Side of Main Bearing Bore to Deck
    189.26 mm
    7.4511 in. min.
    189.26 mm
    7.4511 in. min.
    Longitudinal Deck Warpage
    0.080 mm
    0.0031 in.
    0.10 mm
    0.0040 in. max.
    Transverse Deck Warpage
    0.024 mm
    0.0009 in.
    0.05 mm
    0.0020 in. max.
    Bore Diameter (Middle)
    (Bore No. 2, 3)
    81.990-82.010 mm
    3.2280-3.2287 in.
    82.035 mm
    3.2297 in. max.
    (Bore No.1, 4)
    82.000-82.020 mm
    3.2283-3.2291 in.
    82.045 mm
    3.2301 in. max.
    Re-boring Limit
    0.40 mm
    0.0157 in. max.
    Bore Taper
    0.010 mm
    0.0004 in.
    0.050 mm
    0.0020 in. max.
    Bore Out-of-Round
    0.010 mm
    0.0004 in.
    0.050 mm
    0.0020 in. max.
    Liner Height Depth
    Flush
    Flush
    + 0.013 mm
    + 0.0005 in. max.
    Piston
    Piston Protrusion above Deck
    0.300 mm
    0.0118 in. max.
    0.379 mm
    0.0149 in. max.
    Piston Protrusion below Deck
    0.066 mm
    0.0026 in. max.
    0.145 mm
    0.0057 in. max.
    Skirt Outer Diameter
    (at 5 mm [0.20 in.]
    from bottom of piston)
    81.966-81.992 mm
    3.2270-3.2280 in.
    81.930 mm
    3.2280 in. min.
    Piston-to-Ring (Top)
    0.040-0.070 mm
    0.0016-0.0028 in.
    0.090 mm
    0.0035 in. max.
    Piston-to-Ring (2nd)
    0.030-0.080 mm
    0.0012-0.0031 in.
    0.080 mm
    0.0031 in. max.
    Piston Pin Bore
    19.502-19.507 mm
    0.7678-0.7680 in.
    19.510 mm
    0.7686 in. max.
    Piston Pin Diameter
    19.496-19.500 mm
    0.7676-0.7677 in.
    19.488 mm
    0.7678 in. min.
    Piston Pin Clearance
    0.002-0.011 mm
    0.0001-0.0004 in.
    0.015 mm
    0.0005 in. max.
    Cylinder Clearance
    (Bore 2 and3)
    0.000-0.044 mm
    0.0000-0.0017 in.
    0.070 mm
    0.0028 in. max.
    Cylinder Clearance
    (Bore 1 and 4)
    0.008-0.054 mm
    0.0003-0.0021 in.
    0.070 mm
    0.0028 in. max.
    Piston Ring
    Ring End Gap (Top)
    0.180-0.330 mm
    0.0071-0.0130 in.
    0.450 mm
    0.0177 in. max.
    Ring End Gap (2nd)
    0.350-0.550 mm
    0.0138-0.0216 in.
    0.650 mm
    0.0256 in. max.
    Ring End Gap (Oil)
    0.100-0.500 mm
    0.0039-0.0197 in.
    0.650 mm
    0.0256 in. max.
    Connecting Rod
    Piston Pin Bushing Diameter
    19.505-19.517 mm
    0.7679-0.7683 in.
    19.520 mm
    0.769 in. max.
    Piston Pin-to-Rod Clearance
    0.005-0.021 mm
    0.0002-0.0008 in.
    0.030 mm
    0.0012 in. max.
    Large End Bore Diameter
    50.193-50.207 mm
    1.9761-1.9767 in.
    50.207 mm
    1.9767 in. max.
    Rod Journal Oil Clearnace
    0.003-0.053 mm
    0.0001-0.0021 in.
    0.055 mm
    0.0022 in. max.
    Side Play on Crankshaft
    0.165-0.435 mm
    0.0065-0.01713 in.
    0.470 mm
    0.01850 in. max.
    Maximum Bend per 100 mm
    0.320 mm
    0.0126 in. max.
    0.320 mm
    0.0126 in. max.
    Maximum Twist per 100 mm
    0.160 mm
    0.0063 in. max.
    0.160 mm
    0.0063 in. max.
    Crankshaft
    Main Journal Clearance
    0.006-0.050 mm
    0.0002-0.002 in.
    0.055 mm
    0.0022 in. max.
    Main Journal Diameter
    56.993-57.007 mm
    2.2438-2.2444 in.
    56.990 mm
    2.2437 in. min.
    Main Taper/Out-of-Round
    0.010 mm
    0.0004 in. max.
    0.010 mm
    0.0004 in. max.
    Rod Pin Diameter
    46.990-47.010 mm
    1.8500-1.8508 in.
    46.990 mm
    1.8500 in. min.
    Rod Taper/Out-of-Round
    (Rod Journal)
    0.012 mm
    0.0004 in. max.
    0.010 mm
    0.0004 in. max.
    End Play
    0.050-0.20 mm
    0.0020-0.0079 in.
    0.25 mm
    0.0098 in. max.
    Runout
    0.050 mm
    0.0020 in. max.
    0.050 mm
    0.0020 in. max.
    Cylinder Head (SOHC[L24]) MEASUREMENT
    STANDARD
    SERVICE LIMIT
    METRIC
    ENGLISH
    METRIC
    ENGLISH
    Compression (Hot)
    250 RPM (Open Throttle)
    1310 kPa
    190 psi min.
    1,241 kPa
    180 psi min.
    Cylinder Leakage (Hot)
    689 kPa (100 psi) Input
    69 kPa; 10% max.
    10 psi max.
    138 kPa; 15% max.
    20 psi max.
    Cylinder Head Warpage
    Transverse Deck
    0.03 mm
    0.0012 in. max.
    0.05 mm
    0.002 in. max.
    Longitudinal Deck
    0.07 mm
    0.0028 in. max.
    0.10 mm
    0.004 in. max.
    Intake Flange (Overall)
    0.10 mm
    0.0039 in. max.
    0.15 mm
    0.006 in. max.
    Exhaust Flange (Overall)
    0.10 mm
    0.004 in. max.
    0.15 mm
    0.006 in. max.
    Camshaft Bore (TIR)
    0.05 mm
    0.002 in. max.
    0.064 mm
    0.0025 in. max.
    Cylinder Head
    Lifter Bore Diameter
    (Intake and Exhaust)
    21.422-21.448 mm
    0.8434-0.8444 in.
    21.45 mm
    0.8445 in. max.
    Camshaft Bore Diameter
    44.475-44.500 mm
    1.7510-1.7520 in.
    44.513 mm
    1.753 in. max.
    Head Gasket Deck-to-
    Camshaft Cover Surface
    112.87-113.13 mm
    4.444-4.454 in.
    Valve Guide Bore
    11.337-11.363 mm
    0.446-0.447 in.
    11.368 mm
    0.448 in. max.
    O.S. Guide Bore
    11.587-11.613 mm
    0.456-0.457 in.
    11.613 mm
    0.457 in. max.
    Intake Manifold
    Head Flange Warpage
    0.13 mm
    0.005 in. max.
    0.20 mm
    0.008 in. max.
    Throttle Body Flange
    Warpage
    0.10 mm
    0.004 in. max.
    0.15 mm
    0.006 in. max.
    EGR Flange Warpage
    0.10 mm
    0.004 in. max.
    0.15 mm
    0.006 in. max.
    Exhaust Manifold
    Head Flange Warpage
    0.2 mm
    0.008 in. max.
    0.35 mm
    0.014 in. max.
    Down Pipe Warpage
    0.4 mm
    0.016 in. max.
    0.4 mm
    0.016 in. max.
    Camshaft
    Thrust Clearance (End Play)
    0.070-0.200 mm
    0.0028-0.0079 in.
    0.250 mm
    0.0098 in. max.
    Journal Diameter
    44.399-44.424 mm
    1.7480-1.7490 in.
    44.375 mm
    1.7470 in. min.
    Journal Oil Clearance
    0.051-0.101 mm
    0.0020-0.0040 in.
    0.138 mm
    0.0054 in. max.
    Camshaft Journal Runout (all)
    0.05 mm
    0.0020 in. max.
    0.07 mm
    0.0028 in. max.
    Camshaft Lobe Lift Rise
    6.428-6.493 mm
    0.2531-0.2556 in.
    6.400 mm
    0.2520 in. min.
    Lifter Body Diameter
    21.387-21.405 mm
    0.8420-0.8427 in.
    21.380 mm
    0.8417 in. min.
    Lifter Body Oil Clearance
    0.017-0.061 mm
    0.0007-0.0024 in.
    0.07 mm
    0.0028 in. max.
    Lifter/Roller Total Length
    52.23-52.57 mm
    2.0563-2.0697 in.
    52.15 mm
    2.0531 in. min.
    Lifter Body Guide Flat
    19.18-19.30 mm
    0.7551-0.7598 in.
    19.15 mm
    0.7539 in. min.
    Lifter Guide Plate Width
    19.39-19.52 mm
    0.7634-0.7685 in.
    19.385 mm
    0.7632 in. max.
    Valve
    Intake Stem Outer Diameter
    6.949-6.962 mm
    0.2736-0.2741 in.
    6.935 mm
    0.273 in. min.
    Exhaust Stem Outer Diameter
    6.931-6.950 mm
    0.2736-0.274 in.
    6.915 mm
    0.272 in. min.
    Valve Guide Inner Diameter
    6.987-7.013 mm
    0.2751-0.2761 in.
    7.050 mm
    0.278 in. max.
    Valve Guide Outer Diameter
    11.393-11.407 mm
    0.4485-0.4491 in.
    Intake Stem to Guide Clearance
    0.025-0.064 mm
    0.001-0.0025 in.
    0.115 mm
    0.004 in. max.
    Exhaust Stem to Guide
    Clearance
    0.037-0.082 mm
    0.0015-0.0032 in.
    0.135 mm
    0.005 in. max.
    Intake Total Length
    138.53-139.05 mm
    5.45-5.47 in.
    138.48-139.10 mm
    5.45-5.48 in.
    Exhaust Total Length
    138.73-139.25 mm
    5.46-5.48 in.
    138.68-139.30 mm
    5.45-5.48 in.
    Intake Head Diameter
    39.87-40.13 mm
    1.5699-1.5799 in.
    Exhaust Head Diameter
    33.87-34.13 mm
    1.3335-1.3437 in.
    Intake Margin Width
    0.96-1.11 mm
    0.0378-0.0496 in.
    0.90 mm
    0.035 in. min.
    Exhaust Margin Width
    1.12-1.27 mm
    0.0441-0.0559 in.
    1.00 mm
    0.039 in. min.
    Face Angle
    45.0°-45.5°
    44.75°-45.25°
    45.0°-45.5°
    45.0°-45.5°
    Valve Tip Protrusion
    48.25-48.75 mm
    1.900-1.919 in.
    48.80 mm
    1.921 in. max.
    Valve Seat
    Intake Width
    1.0-1.3 mm
    0.0394-0.0512 in.
    1.6 mm
    0.063 in. max.
    Exhaust Width
    1.3-1.6 mm
    0.0512-0.0630 in.
    1.9 mm
    0.075 in. max.
    Angle (Intake and Exhaust)
    44.5°-45.5°
    44.5°-45.5°
    44.5°-45°
    44.5°-45°
    Valve Seat Outside Diameter
    Intake
    41.573-41.599 mm
    1.6377-1.638 in.
    Exhaust
    35.073-35.099 mm
    1.381-1.382 in.
    Seat Bore (Cylinder Head)
    Intake
    41.487-41.513 mm
    1.633-1.634 in.
    Exhaust
    34.987-35.013 mm
    1.377-1.378 in.
    Valve Spring
    Free Length
    48.001-48.600 mm
    1.8898-1.9134 in.
    Squareness
    2.0 mm
    0.080 in. max.
    2.5 mm
    0.100 in. max.
    Force/Tension at 30.0 mm (1.2
    898-983 N
    202-211 lbs
    870 N
    196 lbs min.
    Force/Tension at 41.0 mm (1.61)
    338-387 N
    76-87 lbs
    328 N
    75 lbs min.
    Rocker Arm
    Shaft Diameter
    15.862-15.875 mm
    0.624-0.625 in.
    15.860 mm
    0.62 in. min.
    Spark Plug
    Number
    21025102
    Gap
    1.0 mm
    .040 in.
    Firing Order
    1-3-4-2
    Cylinder Head (DOHC [LL0]) MEASUREMENT
    STANDARD
    SERVICE LIMIT
    METRIC
    ENGLISH
    METRIC
    ENGLISH
    Compression (Hot)
    1310 kPa
    190 psi min.
    1,241 kPa
    180 psi min.
    69 kPa; 10% max.
    10 psi max.
    138 kPa; 15% max.
    20 psi max.
    Transverse Deck
    0.03 mm
    0.0012 in. max.
    0.05 mm
    0.002 in. max.
    Longitudinal Deck
    0.07 mm
    0.0028 in. max.
    0.10 mm
    0.004 in. max.
    0.10 mm
    0.004 in. max.
    0.15 mm
    0.006 in. max.
    0.10 mm
    0.004 in. max.
    0.15 mm
    0.006 in. max.
    Camshaft Bore (TIR)
    0.05 mm
    0.002 in. max.
    0.064 mm
    0.0025 in. max.
    Cylinder Head
    Lash Adjuster Bore Diameter
    12.008-12.030 mm
    .4371-.4740 in.
    12.040 mm
    .4744 in. max.
    27.000-27.026 mm
    1.0638-1.0648 in.
    27.05 mm
    1.0658 in. max.
    Valve Guide Bore
    11.337-11.363 mm
    0.446-0.447 in.
    11.368 mm
    0.4475 in. max.
    O.S. Guide Bore
    11.587-11.613 mm
    0.456-0.457 in.
    11.613 mm
    0.457 in. max.
    Valve Seat Bore
    Intake
    33.399-33.423 mm
    1.315-1.316 in.
    Exhaust
    28.399-28.423 mm
    1.118-1.119 in.
    Exhaust Manifold
    Head Flange Warpage
    0.25 mm
    0.010 in. max.
    0.35 mm
    0.014 in. max.
    Down Pipe Warpage
    0.4 mm
    0.016 in. max.
    0.40 mm
    0.016 in. max.
    Camshaft
    0.006-0.396 mm
    0.0002-0.0156 in.
    0.45 mm
    0.018 in. max.
    Journal Diameter
    26.950-26.970 mm
    1.0618-1.0626 in.
    26.925 mm
    1.0608 in. min.
    0.030-0.076 mm
    0.0021-0.0030 in.
    0.125 mm
    0.005 in. max.
    0.080 mm
    0.003 in. max.
    0.120 mm
    0.0047 in. max.
    Intake Cam Lobe Lift Rise
    5.183-5.263 mm
    0.2042-0.2074 in.
    5.133 mm
    0.202 in. min.
    Exhaust Cam Lobe Lift Rise
    5.183-5.263 mm
    0.2042-0.2074 in.
    5.133 mm
    0.202 in. min.
    Lash Adjuster Body Diameter
    11.986-12.000 mm
    0.4722-0.4728 in.
    11.980 mm
    0.4672 in. min.
    Lash Adjuster Body Clearance
    0.008-0.044 mm
    0.0003-0.0017 in.
    0.060 mm
    0.0024 in. max.
    Valve
    5.958-5.977 mm
    0.2347-0.2363 in.
    5.945 mm
    0.2342 in. min.
    5.944-5.963 mm
    0.2342-0.2349 in.
    5.930 mm
    0.2336 in. min.
    6.000-6.020 mm
    0.2364-0.2372 in.
    6.06 mm
    0.239 in. max.
    11.393-11.407 mm
    0.448-0.449 in.
    0.023-0.062 mm
    0.0010-0.0025 in.
    0.113 mm
    0.004 in. max.
    Exhaust Stem to
    Guide Clearance
    0.037-0.076 mm
    0.0015-0.0030 in.
    0.131 mm
    0.005 in. max.
    Intake Total Length
    96.28-96.74 mm
    3.7934-3.8116 in.
    96.20-96.74 mm
    3.787-3.812 in.
    95.58-96.04 mm
    3.7659-3.7840 in.
    95.50-96.04 mm
    3.760-3.784 in.
    32.16-32.46 mm
    1.2661-1.2780 in.
    27.30-27.60 mm
    1.0748-1.0866 in.
    Intake Margin Width
    0.75 mm
    0.035 in. min.
    0.75 mm
    0.039 in. min.
    Face Angle
    45.0°-45.5°
    45.0°-45.5°
    45.5°-45°
    45.5°-45°
    39.31-39.98 mm
    1.548-1.567 in.
    39.31-40.28 mm
    1.548-1.586 in. max.
    Valve Seat
    Intake Width
    0.79-1.23 mm
    0.0394-0.0512 in.
    1.66 mm
    0.0653 in. max.
    Exhaust Width
    1.05-1.49 mm
    0.0512-0.0630 in.
    1.92 mm
    0.0756 in. max.
    44.5°-45.5°
    44.5°-45.5°
    44.5°-45°
    44.5°-45°
    Intake
    33.49-33.51 mm
    1.3185-1.3193 in.
    Exhaust
    28.49-28.5 mm
    1.121-1.122 in.
    Valve Spring
    Free Length
    40.10 mm
    1.56 in.
    Squareness
    2.0 mm
    0.080 in. max.
    2.5 mm
    0.100 in. max.
    Force/Tension at 21.50 mm (0.847)
    440-486 N
    99-109 lbs
    420 N
    94 lbs min.
    Force/Tension at 31.00 mm (1.221)
    186-214 N
    42-48 lbs
    180 N
    40 lbs min.
    Spark Plug
    Number
    21025103
    Gap
    1.0 mm
    .040 in.
    Firing Order
    1-3-4-2
    Engine Lubrication (SOHC[L24]/DOHC[LL0]) MEASUREMENT
    STANDARD
    SERVICE LIMIT
    METRIC
    ENGLISH
    METRIC
    ENGLISH
    SOHC (L24) Engine Oil
    Capacity:
    Drain and Refill,
    No Filter Change
    3.4 L
    3.6 qt
    Drain and Refill,
    Filter Change
    3.8 L
    4.0 qt
    Dry Fill
    4.3 L
    4.5 qt
    DOHC (LL0) Engine Oil
    Capacity:
    Drain and Refill,
    No Filter Change
    3.4 L
    3.6 qt
    Drain and Refill,
    Filter Change
    3.8 L
    4.0 qt
    Dry Fill
    4.3 L
    4.5 qt
    Oil Pump
    Displacement
    0.01267-0.01313
    L/rev
    0.01339-0.01388
    qt./rev
    0.01112-0.01152
    imp. qt./rev
    Tip Clearance
    0.150 mm
    0.006 in. max.
    0.150 mm
    0.006 in. max.
    End-to-End Clearance
    0.040-0.125 mm
    0.0016-0.0049 in.
    0.128 mm
    0.005 in. max.
    Body-to-Side Clearance
    0.150-0.277 mm
    0.006-0.011 in.
    0.277 mm
    0.011 in. max.
    Regulator Valve
    5W 30 EC II Oil
    (With Starburst Symbol)
    Pressure Setting at 90°C
    (195°F) Coolant Temperature
    at Idle RPM
    90 kPa
    13.0 psi min.
    65 kPa
    9.0 psi min.
    at 2000 RPM
    250 kPa
    36.0 psi min.
    200 kPa
    29.0 psi min.
    Cold (up to 2500 rpm)
    560 kPa
    80 psi max.
    Cam Drive System (SOHC[L24]/DOHC[LL0]) MEASUREMENT
    STANDARD
    SERVICE LIMIT
    METRIC
    ENGLISH
    METRIC
    ENGLISH
    Tensioner
    Plunger Extended
    (Chain Installed, LL0, L24)
    1.16-9.85 mm
    0.045-0.388 in.
    18.0 mm
    0.7092 in. max.
    Guide
    Groove Wear (Chain Track)
    0.0 mm
    0.0 in.
    1.0 mm
    0.0394 in. max.
    Accessory Drive Belt/Tensioner (SOHC[L24]/DOHC[LL0]) MEASUREMENT
    STANDARD
    SERVICE LIMIT
    METRIC
    ENGLISH
    METRIC
    ENGLISH
    Belt/Pulley
    Tension
    22.7-29.2 kg
    50-65 lbs.
    20.4 kg
    45 lb. min.
    Pulley Radial / Axial Runout
    0.38 mm
    0.015 in. max.
    Notice: Measured at pulley belt grooves.
    Cooling System (SOHC[L24]/DOHC[LL0]) MEASUREMENT
    STANDARD
    SERVICE LIMIT
    METRIC
    ENGLISH
    METRIC
    ENGLISH
    Radiator
    Capacity - SOHC (L24)
    (Including Reservoir Tank)
    6.75 L
    7.0 qt.
    Capacity - DOHC (LL0)
    6.75 L
    7.0 qt.
    Surge Tank Pressure Cap
    Cap Opening Pressure
    89.6-138 kPa
    13-20.0 psi
    Vacuum Relief Setting
    0-6.9 kPa
    0-1.0 psi
    below Atmospheric Pressure
    Torque
    2.5-3.5 N·m
    22-31 in-lb.
    Thermostat
    Starts to Open
    84°-88°C
    182°-190°F
    83°-89°C
    180°-192°F
    Full Open
    100°C
    212°F
    105°C
    222°F
    Minimum Valve Lift at Full
    Open
    7.5 mm
    0.295 in.
    6.0 mm
    0.236 in.
    Inlet Diameter
    38.0 mm
    1.4961 in.
    Minimum Valve Leakage
    (Max. Pints After 5 Minutes)
    0.89 L max.
    (1.68 pts. max.)
    0.94 L max.
    (2.0 pts. max.)
    Water Pump
    Pulley Ratio (Crankshaft)
    1.3:1
    1.3:1
    Capacity at 6000 rpm
    166.5 l/min.
    176.0 qt./min.
    146.1 imp. qt./min.
    151.4 l/min.
    160 qt./min.
    132.8 imp. qt./min.
    Inlet Housing Depth
    17.650-18.150 mm
    0.6949-0.7146 in.
    17.648-18.152 mm
    0.6948-0.7146 in.
    Cooling Fan
    Fan to Core Clearance
    25.0 mm
    0.9843 in.
    Thermoswitch On Temp.
    105.5°C
    222°F
    Thermoswitch Off Temp.
    100.5°C
    213°F
    Antifreeze
    Dex-Cool™
    Mixture 50/50
    Fuel and Emission System (SOHC[L24]/DOHC[LL0]) MEASUREMENT
    STANDARD
    SERVICE LIMIT
    METRIC
    ENGLISH
    METRIC
    ENGLISH
    Air System
    Intake Manifold Vacuum
    (No Load)
    Idle: 73 kPa
    50 kPa
    21 in. Hg max.
    15 in. Hg min.
    Air Inlet Restriction
    (No Load) Between Air Filter and Throttle Body
    4000 rpm: 60 kPa
    20 in. Hg max.
    Crankcase Pressure / Vacuum
    at 4,000 rpm (No Load)
    Positive: 1.0 kPa
    4.0 in. H2 O max.
    Positive: 2.5 kPa
    10.0 in. H2 O max.
    Coolant Temperature 90°C
    (195°F)
    Negative: 3.0 kPa
    12.0 in. H2 O max.
    Negative: 3.5 kPa
    14.0 in. H2 O max.
    Fuel Pump
    SOHC (L24)/DOHC (LLO)
    Dead Head Pressure at
    12 volts
    450-650 kPa
    65-94 psi
    Pressure Decay
    55 kPa
    8 psi max.
    Fuel System (SOHC (L24)/ DOHC [LL0] )
    Operating Pressure
    276-370 kPa
    40-55 psi
    Pressure Decay in 5 Minutes
    55 kPa
    8 psi max.
    Fuel Tank
    Capacity
    45.9 L
    12.1 gal.
    Fuel and Emission System (SOHC[L24]/DOHC[LL0]) Cont'd SPECIFICATION
    RPM
    TRANSAXLE GEAR
    FUEL CUT-OFF RPM
    Idle Speed (rpm)
    SOHC (L24)
    Manual (AC On/Off)
    750 ± 50
    Neutral
    SOHC (L24)
    5750 ± 150
    SOHC (L24) Automatic
    650 ± 50
    Drive
    SOHC (L24)
    6000 ± 150
    (With A/C On)
    775 ± 50
    Drive
    DOHC (LL0)
    6750 ± 150
    DOHC (LL0) Manual
    (With A/C On)
    850 ± 50
    875 ± 50
    Neutral
    Neutral
    DOHC (LL0) Automatic
    (With A/C On)
    750 ± 50
    775 ± 50
    Drive
    Drive
    Min. Air Idle Speed
    (SOHC [L24] and
    DOHC [LL0])
    0 rpm (Stall)
    to 700 rpm
    Neutral
    Note: Do not adjust minimum idle speed.
    Exhaust System (SOHC[L24]/DOHC[LL0]) MEASUREMENT
    STANDARD
    SERVICE LIMIT
    METRIC
    ENGLISH
    METRIC
    ENGLISH
    Exhaust Back Pressure
    (195°F)
    5.0 kPa
    1.5 in. Hg max.
    Note: Wide open throttle checks are performed at 15 mph in "D" for auto transaxles and third gear for manual transaxles.
    Wide Open Throttle Check
    50 kPa
    7.25 psi max.
    ------- MIKE --------
    WARNING: The following posts may contain and are most likely the result of any/all of the following. Boredom, laziness, apathy, lack of sleep, alchahol and a strong desire to be a jackass for no good reason other than because I can and am. Please read and take any or all posts with a grain of salt and a sense of humor. Not responsible for any butt-hurt, bad attitudes, or temper tantrums. By reading this, you have accepted this warning as a warning, therefore you have been warned, Thank you.
      2nd Gen S series
      Design Specifications (SOHC L24/DOHC LL0) Item
      Specifications
      Specifications
      Type - SOHC (L24)
      Water Cooled - 4 Cycle SOHC
      Type - DOHC (LL0)
      Water Cooled - 4 Cycle DOHC
      Horsepower - 1998
      SOHC (L24) - 100 hp at 5,000 RPM
      DOHC (LL0) - 124 hp at 5,600 RPM
      SOHC (L24) - 74.5 Kw at 5,000 RPM
      DOHC (LL0) - 93 Kw at 5,600 RPM
      Torque
      SOHC (L24) - 114 lb ft at 2,400 RPM
      DOHC (LL0) - 122 lb ft at 4,800 RPM
      SOHC (L24) - 155 N·m at 2,400 RPM
      DOHC (LL0) - 165N·m at 4,800 RPM
      Bore and Stroke
      82 mm x 90 mm
      (3.2 in x 3.5 in)
      Compression Ratio
      SOHC (L24) - 9.3:1
      DOHC (LL0) - 9.5:1
      Displacement
      1.9 liter (116 cu in)
      Valve Train - SOHC (L24)
      2 Valves Per Cylinder - SOHC
      Valve Train - DOHC (LL0)
      4 Valves Per Cylinder - DOHC
      Lubrication System
      Pressure Feed
      Fuel System
      Unleaded Grade Gasoline, 87 Octane (R+M) Divided by 2
      Engine Net Weight (No Accessories)
      SOHC (L24)
      DOHC (LL0)
      89.223 kg (196.74 lb)
      99.872 kg (220.22 lb)
      Engine Block SOHC (L24)/DOHC (LL0) Measurement
      Standard
      Service Limit
      Metric
      English
      Metric
      English
      Cylinder Block
      189.26 mm
      7.4511 in min
      189.26 mm
      7.4511 in min
      0.08 mm
      0.0031 in
      0.1 mm
      0.004 in max
      0.024 mm
      0.0009 in
      0.05 mm
      0.002 in max
      Bore Diameter Middle
      (Bore No. 1, 2, 3)
      81.99-82.01 mm
      3.228-3.2287 in
      82.035 mm
      3.2297 in max
      (Bore No. 4)
      82-82.02 mm
      3.2283-3.2291 in
      82.045 mm
      3.2301 in max
      Re-boring Limit
      0.4 mm
      0.0157 in max
      Bore Taper
      0.01 mm
      0.0004 in
      0.05 mm
      0.002 in max
      Bore Out-of-Round
      0.01 mm
      0.004 in
      0.05 mm
      0.002 in max
      Liner Height Depth
      Flush
      Flush
      +/-0.013 mm
      +/-0.005 in max
      Piston
      0.3 mm
      0.0118 in max
      0.379 mm
      0.0149 in max
      0.066 mm
      0.0026 in max
      0.145 mm
      0.0057 in max
      Skirt Outer Diameter, at 5 mm (0.2 in) from bottom of piston
      81.966-81.984 mm
      3.227-3.2277 in
      81.956 mm
      3.2266 in min
      0.04-0.08 mm
      0.0016-0.0032 in
      0.09 mm
      0.0035 in max
      0.03-0.08 mm
      0.0012-0.0031 in
      0.08 mm
      0.0031 in max
      Piston Pin Bore
      19.502-19.507 mm
      0.7678-0.768 in
      19.507 mm
      0.768 in max
      Piston Pin Diameter
      19.496-19.5 mm
      0.7676-0.7677 in
      19.496 mm
      0.7676 in min
      0.002-0.011 mm
      0.0001-0.0004 in
      0.011 mm
      0.0004 in max
      Cylinder Clearance (Bore 1, 2, 3)
      0.006-0.044 mm
      0.0002-0.0017 in
      0.07 mm
      0.0028 in max
      Cylinder Clearance (Bore 4)
      0.016-0.054 mm
      0.0006-0.0021 in
      0.07 mm
      0.0028 in max
      Piston Ring
      Ring End Gap (Top)
      0.25-0.4 mm
      0.0098-0.0157 in
      0.5 mm
      0.0197 in max
      Ring End Gap (2nd)
      0.25-0.5 mm
      0.0098-0.0197 in
      0.6 mm
      0.0236 in max
      Ring End Gap (Oil)
      0.25-1.25 mm
      0.0098-0.0492 in
      1.4 mm
      0.0551 in max
      Connecting Rod
      Piston Pin Bore to Crankshaft journal Bore
      144.97-145.03 mm
      5.707-5.709 in
      144.97 mm
      5.707 in min
      19.506-19.520 mm
      0.7679-0.7685 in
      19.526 mm
      0.769 in max
      0.006-0.024 mm
      0.0002-0.0009 in
      0.03 mm
      0.0012 in max
      50.193-50.207 mm
      1.9761-1.9767 in
      50.207 mm
      1.9767 in max
      Rod Journal Oil Clearance
      0.003-0.053 mm
      0.0001-0.0021 in
      0.063 mm
      0.0025 in max
      0.165-0.435 mm
      0.0065-0.01713 in
      0.47 mm
      0.0185 in max
      0.32 mm
      0.0126 in max
      0.32 mm
      0.0126 in max
      0.28 mm
      0.011 in max
      0.28 mm
      0.011 in max
      Crankshaft
      0.006-0.05 mm
      0.0002-0.002 in
      0.06 mm
      0.0024 in max
      56.993-57.007 mm
      2.2438-2.2444 in
      56.99 mm
      2.2437 in min
      0.01 mm
      0.0004 in max
      0.01 mm
      0.0004 in max
      Rod Pin Clearance
      0.01-0.065 mm
      0.00039-0.0025 in
      0.073 mm
      0.0029 in max
      Rod Pin Diameter
      46.99-47.01 mm
      1.85-1.8508 in
      46.99 mm
      1.85 in min
      Rod Tper/Out-of-Round (Rod Journal)
      0.012 mm
      0.0004 in max
      0.01 mm
      0.0004 in max
      End Play
      0.05-0.2 mm
      0.002-0.0079 in
      0.25 mm
      0.0098 in max
      Runout
      0.05 mm
      0.002 in max
      0.05 mm
      0.002 in max
      Cylinder Head SOHC (L24) Measurement
      Standard
      Service Limit
      Metric
      English
      Metric
      English
      Compression (Hot)
      1 310 kPa
      190 psi min
      1 241 kPa
      180 psi min
      69 kPa (10% max)
      10 psi max
      138 kPa (15% max)
      20 psi max
      Transverse Deck
      0.03 mm
      0.0012 in max
      0.05 mm
      0.002 in max
      Longitudinal Deck
      0.07 mm
      0.0028 in max
      0.1 mm
      0.004 in max
      0.1 mm
      0.004 in max
      0.015 mm
      0.006 in max
      0.1 mm
      0.004 in max
      0.15 mm
      0.006 in max
      Camshaft Bore (TIR)
      0.05 mm
      0.002 in max
      0.064 mm
      0.0025 in max
      Cylinder Head
      Lifter Bore Diameter (Intake and Exhaust)
      21.422-21.448 mm
      0.8434-0.8444 in
      21.45 mm
      0.8445 in max
      44.475-44.5 mm
      1.751-1.752 in
      44.513 mm
      1.753 in max
      Head Gasket Deck-to-Camshaft Cover Surface
      112.87-113.13 mm
      4.444-4.454 in
      Valve Guide Bore
      11.337-11.363 mm
      0.446-0.447 in
      11.368 mm
      0.448 in max
      O.S. Guide Bore
      11.587-11.613 mm
      0.456-0.457 in
      11.613 mm
      0.457 in max
      Intake Manifold
      Head Flange Warpage
      0.13 mm
      0.005 in max
      0.2 mm
      0.008 in max
      Throttle Body Flange Warpage
      0.1 mm
      0.004 in max
      0.15 mm
      0.006 in max
      EGR Flange Warpage
      0.1 mm
      0.004 in max
      0.15 mm
      0.006 in max
      Exhaust Manifold
      Head Flange Warpage
      0.2 mm
      0.008 in max
      0.35 mm
      0.014 in max
      Down Pipe Warpage
      0.4 mm
      0.016 in max
      0.4 mm
      0.016 in max
      Camshaft
      0.07-0.2 mm
      0.0028-0.0079 in
      0.25 mm
      0.0098 in max
      Journal Diameter
      44.399-44.424 mm
      1.748-1.749 in
      44.375 mm
      1.747 in min
      0.051-0.101 mm
      0.002-0.004 in
      0.138 mm
      0.0054 in max
      Camshaft Journal Runout (All)
      0.05 mm
      0.002 in max
      0.07 mm
      0.0028 in max
      Camshaft Lobe Lift Rise (Intake and Exhaust)
      6.428-6.493 mm
      0.2531-0.2556 in
      6.4 mm
      0.252 in min
      21.387-21.405 mm
      0.842-0.8427 in
      21.38 mm
      0.8417 in max
      0.017-0.061 mm
      0.0007-0.0024 in
      0.07 mm
      0.0028 in max
      52.23-52.57 mm
      2.0563-2.0697 in
      52.15 mm
      2.0531 in min
      19.18-19.3 mm
      0.7551-0.7598 in
      19.15 mm
      0.7539 in min
      19.39-19.52 mm
      0.7634-0.7685 in
      19.385 mm
      0.7632 in max
      Valve
      6.949-6.962 mm
      0.2736-0.2741 in
      6.935 mm
      0.273 in min
      6.931-6.95 mm
      0.2736-0.274 in
      6.915 mm
      0.272 in min
      6.987-7.013 mm
      0.2751-0.2761 in
      7.05 mm
      0.278 in max
      11.393-11.407 mm
      0.4485-0.4491 in
      0.025-0.064 mm
      0.001-0.0025 in
      0.115 mm
      0.004 in max
      Exhaust Stem to Guide Clearance
      0.037-0.082 mm
      0.0015-0.0032 in
      0.135 mm
      0.005 in max
      Intake Total Length
      138.53-139.05 mm
      5.45-5.47 in
      138.48-139.1 mm
      5.45-5.48 in
      138.73-139.25 mm
      5.46-5.48 in
      138.68-139.3 mm
      5.45-5.48 in
      39.87-40.13 mm
      1.5699-1.5799 in
      33.87-34.13 mm
      1.3335-1.3437 in
      Intake Margin Width
      0.96-1.11 mm
      0.0378-0.0496 in
      0.9 mm
      0.035 in min
      1.12-1.27 mm
      0.0441-0.0559 in
      1 mm
      0.039 in min
      Face Angle (Intake and Exhaust)
      45-45.5°
      44.75-45.25°
      45-45.5°
      45-45.5°
      48.25-48.75 mm
      1.9-1.919 in
      48.8 mm
      1.921 in max
      Valve Seat
      Intake Width
      1-1.3 mm
      0.0394-0.0512 in
      1.6 mm
      0.063 in max
      Exhaust Width
      1.3-1.6 mm
      0.0512-0.063 in
      1.9 mm
      0.075 in max
      44.5-45.5°
      44.5-45.5°
      44.5-45°
      44.5-45°
      Valve Set Outside Diameter
      Intake
      41.573-41.599 mm
      1.6377-1.638 in
      Exhaust
      35.073-35.099 mm
      1.381-1.382 in
      Intake
      41.487-41.513 mm
      1.633-1.634 in
      Exhaust
      34.987-35.013 mm
      1.377-1.378 in
      Valve Spring
      Free Length (Intake and Exhaust)
      48.001-48.6 mm
      1.8898-1.9134 in
      Squareness
      2 mm
      0.08 in max
      2.5 mm
      0.1 in max
      Force/Tension at 30 mm (1.18 in)
      898-983 N
      202-211 lbs
      870 N
      196 lbs min
      Force/Tension at 41 mm (1.61 in)
      338-387 N
      76-87 lbs
      328 N
      75 lbs min
      Rocker Arm
      Shaft Diameter
      15.862-15.875 mm
      0.624-0.625 in
      15.86 mm
      0.62 in min
      Spark Plug
      Number
      AC41-628
      Gap
      1 mm
      0.04 in
      Firing Order
      1-3-4-2
      Cylinder Head DOHC (LL0) Measurement
      Standard
      Service Limit
      Metric
      English
      Metric
      English
      Compression (Hot)
      1 310 kPa
      190 psi min
      1 241 kPa
      180 psi min
      69 kPa (10% max)
      10 psi max
      138 kPa (15% max)
      20 psi max
      Transverse Deck
      0.03 mm
      0.0012 in max
      0.05 mm
      0.002 in max
      Longitudinal Deck
      0.07 mm
      0.0028 in max
      0.1 mm
      0.004 in max
      0.1 mm
      0.004 in max
      0.015 mm
      0.006 in max
      0.1 mm
      0.004 in max
      0.15 mm
      0.006 in max
      Camshaft Bore (TIR)
      0.05 mm
      0.002 in max
      0.064 mm
      0.0025 in max
      Cylinder Head
      33-33.025 mm
      1.2992-1.3002 in
      33.03 mm
      1.3 in max
      29-29.026 mm
      1.141-1.142 in
      29.05 mm
      1.144 in max
      112.87-113.13 mm
      4.4449-4.4527 in
      Camshaft Cover-to-Plug Well Surface
      130.9-131.1 mm
      5.1535-51.614 in
      Valve Guide Bore
      11.337-11.363 mm
      0.446-0.447 in
      11.368 mm
      0.4475 in max
      O.S. Guide Bore
      11.587-11.613 mm
      0.456-0.457 in
      11.613 mm
      0.457 in max
      Valve Seat Bore
      Intake
      33.399-33.423 mm
      1.315-1.316 in
      Exhaust
      28.399-28.423 mm
      1.118-1.119 in
      Intake Manifold
      Head Flange Warpage
      0.13 mm
      0.0051 in max
      0.2 mm
      0.008 in max
      0.1 mm
      0.004 in max
      0.15 mm
      0.006 in max
      EGR Flange Warpage
      0.1 mm
      0.004 in max
      0.15 mm
      0.006 in max
      Exhaust Manifold
      Head Flange Warpage
      0.25 mm
      0.01 in max
      0.35 mm
      0.014 in max
      Down Pipe Warpage
      0.4 mm
      0.016 in max
      0.4 mm
      0.016 in max
      Camshaft
      0.05-0.2 mm
      0.002-0.008 in
      0.25 mm
      0.01 in max
      Journal Diameter
      28.95-28.97 mm
      1.1398-1.1406 in
      28.925 mm
      1.139 in min
      0.03-0.076 mm
      0.0021-0.003 in
      0.125 mm
      0.005 in max
      0.05 mm
      0.002 in max
      0.1 mm
      0.004 in max
      8.96-9.04 mm
      0.3528-0.3599 in
      8.91 mm
      0.351 in min
      8.66-8.74 mm
      0.3409-0.3441 mm
      8.61 mm
      0.339 in min
      32.959-32.975 mm
      1.2976-1.2982 in
      32.947 mm
      1.297 in max
      0.017-0.061 mm
      0.0007-0.0024 in
      0.07 mm
      0.0028 in max
      Lifter Body Clearance
      0.025-0.066 mm
      0.001-0.0026 in
      0.083 mm
      0.003 in max
      Valve
      6.949-6.962 mm
      0.2736-0.274 in
      6.935 mm
      0.273 in min
      6.931-6.95 mm
      0.2726-0.2736 in
      6.919 mm
      0.272 in min
      6.987-7.013 mm
      0.275-0.276 in
      7.05 mm
      0.278 in max
      11.393-11.407 mm
      0.448-0.449 in
      0.025-0.064 mm
      0.001-0.0025 in
      0.113 mm
      0.004 in max
      0.037-0.082 mm
      0.0015-0.0032 in
      0.131 mm
      0.005 in max
      Intake Total Length
      100.72-101.18 mm
      3.9654-3.9835 in
      100.64-101.26 mm
      5.45-5.48 in
      100.02-101.48 mm
      3.9378-3.9559 in
      99.94-100.56 mm
      5.45-5.48 in
      32.16-32.46 mm
      1.2661-1.278 in
      27.3-27.6 mm
      1.0748-1.0866 in
      Intake Margin Width
      0.75 mm
      0.035 in min
      0.75 mm
      0.039 in min
      45-45.5°
      45-45.5°
      45.5-45°
      45.5-45°
      40.95-41.55 mm
      1.612-1.636 in
      41.6 mm
      1.638 in max
      Valve Seat
      Intake Width
      0.79-1.23 mm
      0.0394-0.0512 in
      1.66 mm
      0.0653 in max
      Exhaust Width
      1.05-1.49 mm
      0.0512-0.063 in
      1.92 mm
      0.0756 in max
      44.5-45.5°
      44.5-45.5°
      44.5-45°
      44.5-45°
      Intake
      33.49-33.51 mm
      1.3185-1.3193 in
      Exhaust
      28.49-28.5 mm
      1.121-1.122 in
      Valve Spring
      41.8 mm
      1.65 in
      Squareness
      2 mm
      0.08 in max
      2.5 mm
      0.1 in max
      Force/Tension at 26.25 mm (0.984 in)
      724-788 N
      163-177 lbs
      688 N
      155 lbs min
      Force/Tension at 35.25 mm (1.388 in)
      293-329 N
      66-74 lbs
      278 N
      63 lbs min
      Spark Plug
      Number
      AC41-627
      Gap
      1 mm
      0.04 in
      Firing Order
      1-3-4-2
      Engine Lubrication SOHC(L24)/DOHC (LL0) Measurement
      Standard
      Service Limit
      Metric
      English
      Metric
      English
      SOHC (L24) Engine Oil Capacity:
      Drain and Refill, No Filter Change
      3.4 L
      3.6 qt
      Drain and Refill, Filter Change
      3.8 L
      4 qt
      Dry Fill
      4.3 L
      4.5 qt
      DOHC (LL0) Engine Oil Capacity
      3.4 L
      3.6 qt
      3.8 L
      4 qt
      Dry Fill
      4.3 L
      4.5 qt
      Oil Pump
      Displacement
      0.01267-0.01313 L/rev
      0.01339-0.01388 qt/rev
      0.01112-0.01152 imp. qt/rev
      Tip Clearance
      0.15 mm
      0.006 in max
      0.15 mm
      0.006 in max
      0.04-0.125 mm
      0.0016-0.0049 in
      0.128 mm
      0.005 in max
      0.15-0.277 mm
      0.006-0.011 in
      0.277 mm
      0.011 in max
      Regulator Valve
      5W-30 EC II Oil (With Starburst Symbol)
      Pressure Setting at 90°C (195°F) Coolant Temperature at Idle RPM
      90 kPa
      13 psi min
      65 kPa
      9 psi min
      at 2,000 RPM
      250 kPa
      36 psi min
      200 kPa
      29 psi min
      Cold (Up to 2,500 RPM)
      560 kPa
      80 psi max
      Cam Drive System SOHC (L24)/DOHC (LL0) Measurement
      Standard
      Service Limit
      Metric
      English
      Metric
      English
      Tensioner
      Plunger Extended (Chain Installed, L24)
      1.5-10.5 mm
      0.059-0.413 in
      21 mm
      0.8626 in max
      Plunger Extended (Chain Installed, LL0)
      1.5-9.5 mm
      0.059-0.374 in
      21 mm
      0.8626 in max
      Chain
      Length (Inner Diameter, L24)
      419-422 mm
      16.5-16.61 in
      425 mm
      16.73 in max
      Length (Inner Diameter, LL0)
      581-584 mm
      22.87-22.99 in
      588 mm
      23.15 in max
      Guide
      0 mm
      0 in
      2.5 mm
      0.0984 in max
      Accessory Drive Belt/Tensioner SOHC (L24)/DOHC (LL0) Measurement
      Standard
      Service Limit
      Metric
      English
      Metric
      English
      Belt/Pulley
      Tension
      22.7-29.2 kg
      50-65 lbs
      20.4 kg
      45 lb min
      Pulley Radial/Axial Runout
      0.38 mm
      0.015 in max
      Note: Measured at pulley belt grooves.
      Cooling System SOHC (L24)/DOHC (LL0) Measurement
      Standard
      Service Limit
      Metric
      English
      Metric
      English
      Radiator
      Capacity -SOHC (L24), Including Reservoir Tank
      6.75 L
      7 qt
      Capacity - DOHC (LL0), Including Reservoir Tank
      6.75 L
      7 qt
      89.6-138 kPa
      13-20 psi
      0-6.9 kPa
      0-1 psi
      Below Atmospheric Pressure
      Torque
      2.5-3.5 N·m
      23-31 lb in
      Thermostat
      Starts to Open
      84-88°C
      182-190°F
      83-89°C
      180-192°F
      Full Open
      100°C
      212°F
      105°C
      222°F
      Minimum Valve Lift at Full Open
      7.5 mm
      0.295 in
      6 mm
      0.236 in
      Inlet Diameter
      38 mm
      1.4961 in
      Minimum Valve Leakage (Max. Pints After 5 Minutes)
      0.89 L max
      1.68 pts max
      0.94 L max
      2 pts max
      Water Pump
      1.3:1
      1.3:1
      Capacity at 6,000 RPM
      166.51/min
      176 qt/min
      151.41/min
      160 qt/min
      146.1 imp qt/min
      132.8 imp qt/min
      Inlet Housing Depth
      17.65-18.15 mm
      0.6949-0.7146 in
      17.648-18.152 mm
      0.6948-0.7146 in
      Cooling Fan
      25 mm
      0.9843 in
      Thermoswitch ON Temp
      105.5°C
      222°F
      Thermoswitch OFF Temp
      100.5°C
      213°F
      Antifreeze
      DEX-COOL™
      Mixture 50/50
        The 1st gen are not published in GM so I an get them from the manuals at work tommorow but I shure as hell wont type them all in. I will try to post all the differences once I get time.
          2.0 LSJ Supercharged
          Engine Mechanical Specifications Application
          Specification
          Metric
          English
          General Data
          •Engine Type
          Inline 4 Cylinder
          •Displacement
          2.0 L
          122 CID
          •RPO
          LSJ
          •Liter (VIN)
          P
          •Bore
          85.992-86.008 mm
          3.3855-3.3861 in
          •Stroke
          86 mm
          3.388 in
          •Compression Ratio
          9.5:1
          Balance Shaft
          •Bearing Clearance
          0.030-0.063 mm
          0.0012-0.0025 in
          •Bearing Diameter - Inside - Carrier
          20.050-20.063 mm
          0.7894-0.7899 in
          •Bearing Diameter - Outside - Carrier
          41.975-41.995 mm
          1.6526-1.6534 in
          •Bearing Journal Diameter
          20.000-20.020 mm
          0.7874-0.7882 in
          •Bushing Clearance
          0.033-0.102 mm
          0.0013-0.0040 in
          •Bushing Diameter - Inside
          36.776-36.825 mm
          1.4479-1.4498 in
          •Bushing Journal Diameter
          36.723-36.743 mm
          1.4458-1.4466 in
          •End Play
          0.100-0.300 mm
          0.0020-0.0118 in
          Block
          •Balance Shaft Bearing Bore Diameter - Carrier
          42.000-42.016 mm
          1.6535-1.6542 in
          •Balance Shaft Bushing Bore Diameter
          40.763-40.776 mm
          1.6048-1.6054 in
          •Crankshaft Main Bearing Bore Diameter
          64.068-64.082 mm
          2.5224-2.5229 in
          •Cylinder Bore Diameter
          85.992-86.008 mm
          3.3855-3.3861 in
          •Cylinder Bore Out-of-Round - Maximum
          0.010 mm
          0.0004 in
          •Cylinder Bore Taper - Maximum
          0.010 mm
          0.0004 in
          •Cylinder Head Deck Surface Flatness - Longitude
          0.050 mm
          0.002 in
          •Cylinder Head Deck Surface Flatness - Overall
          0.08 mm
          0.0031 in
          •Cylinder Head Deck Surface Flatness - Transverse
          0.030 mm
          0.0012 in
          Camshaft
          •Camshaft End Play
          0.040-0.144 mm
          0.0016-0.0057 in
          •Camshaft Journal Diameter
          26.935-26.960 mm
          1.0604-1.0614 in
          •Camshaft Thrust Surface
          21.000-21.052 mm
          0.8268-0.8252 in
          Connecting Rod
          •Connecting Rod Bearing Clearance
          0.029-0.069 mm
          0.0011-0.0027 in
          •Connecting Rod Bore Diameter - Bearing End
          52.118-52.134 mm
          2.0519-2.05252 in
          •Connecting Rod Bore Diameter - Pin End
          23.007-23.017 mm
          0.9058-0.9062 in
          •Connecting Rod Side Clearance
          0.070-0.370 mm
          0.0028-0.0146 in
          •Connecting Rod Straightness - Bend - Maximum
          0.021 mm
          0.0083 in
          •Connecting Rod Straightness - Twist - Maximum
          0.04 mm
          0.0157 in
          Crankshaft
          •Connecting Rod Journal Diameter
          49.000-49.014 mm
          1.9291-1.9297 in
          •Crankshaft End Play
          0.050-0.380 mm
          0.0012-0.0150 in
          •Crankshaft Main Bearing Clearance
          0.031-0.067 mm
          0.0012-0.0026 in
          •Crankshaft Main Journal Diameter
          55.994-56.008 mm
          2.2045-2.2050 in
          Cylinder Head
          •Cylinder Head Height/Thickness - measured from cylinder head deck to the cam cover sealing surface
          128.65 mm
          5.06 in
          •Surface Flatness - Block Deck - Longitude
          0.050 mm
          0.002 in
          •Surface Flatness - Block Deck - Overall
          0.1 mm
          0.004 in
          •Surface Flatness - Block Deck - Transverse
          0.030 mm
          0.0012 in
          •Valve Guide Bore - Exhaust
          6.000-6.012 mm
          0.2362-0.2367 in
          •Valve Guide Bore - Intake
          6.000-6.012 mm
          0.2362-0.2367 in
          •Valve Lifter Bore Diameter - Stationary Lash Adjusters
          12.013-12.037 mm
          0.4730-0.4739 in
          Lubrication System
          •Oil Pressure - Minimum - @1000 RPM @ 90°C (194°F)
          206.84-482.63 kPa
          30-70 psi
          •Oil Capacity - with Filter
          5.7L
          6 quarts
          Piston Rings
          •Piston Ring End Gap - First Compression Ring
          0.20-0.40 mm
          0.008-0.016 in
          •Piston Ring End Gap - Second Compression Ring
          0.35-0.55 mm
          0.014-0.022 in
          •Piston Ring End Gap - Oil Control Ring - Rails
          0.25-0.76 mm
          0.010-0.030 in
          •Piston Ring to Groove Clearance - First Compression Ring
          0.04-0.08 mm
          0.0015-0.0031 in
          •Piston Ring to Groove Clearance - Second Compression Ring
          0.030-0.069 mm
          0.0012-0.0027 in
          •Piston Ring to Groove Clearance - Oil Control Ring
          0.090-0.106 mm
          0.0035-0.0042 in
          •Piston Ring Thickness - First Compression Ring
          1.170-1.190 mm
          0.0461-0.0469 in
          •Piston Ring Thickness - Second Compression Ring
          1.471-1.490 mm
          0.0579-0.0587 in
          •Piston Ring Thickness - Oil Control Ring - Rail - Maximum
          0.43 mm
          0.0169 in
          •Piston Ring Thickness - Oil Control Ring - Spacer
          1.574-1.651 mm
          0.0620-0.0650 in
          Pistons and Pins
          •Pin - Piston Pin Clearance to Connecting Rod Bore
          0.007-0.026 mm
          0.0003-0.0010 in
          •Pin - Piston Pin Clearance to Piston Pin Bore
          0.002-0.012 mm
          0.0001-0.0005 in
          •Pin - Piston Pin Diameter
          19.995-20.000 mm
          0.7872-0.7874 in
          •Pin - Piston Pin End Play
          0.19-1.16 mm
          0.0075-0.0461 in
          •Piston - Piston Diameter - @14.5 mm up
          85.967-85.982 mm
          3.3845-3.3851 in
          •Piston - Piston Pin Bore Diameter
          23.005-23.010 mm
          0.9057-0.9059 in
          •Piston - Piston Ring Grove Width - Top
          1.23-1.25 mm
          0.0484-0.0492 in
          •Piston - Piston Ring Grove Width - Second
          1.52-1.54 mm
          0.0598-0.0606 in
          •Piston - Piston Ring Grove Width - Oil Control
          2.52-2.54 mm
          0.0992-0.1000 in
          •Piston - Piston To Bore Clearance
          0.010-0.041 mm
          0.0004-0.0016 in
          Valve System
          •Valves - Valve Face Runout - Maximum
          0.04 mm
          0.0016 in
          •Valves - Valve Seat Runout - Maximum
          0.05 mm
          0.0020 in
          •Valves - Valve Stem Diameter - Exhaust
          5.935-5.950 mm
          0.2337-0.2343 in
          •Valves - Valve Stem Diameter - Intake
          5.955-5.970 mm
          0.2344-0.2355 in
          •Valves - Valve Stem to Guide Clearance - Exhaust
          0.050-0.077 mm
          0.0020-0.0026 in
          •Valves - Valve Stem to Guide Clearance - Intake
          0.030-0.057 mm
          0.0012-0.0022 in
          •Valve Lifters - Valve Lifter Diameter - Stationary Lash Adjuster
          11.986-12.000 mm
          0.0005-0.0020 in
          •Valve Lifters - Valve Lifter-to-Bore Clearance - Stationary Lash Adjuster
          0.013-0.051 mm
          3.2210-3.2299 in
          •Valve Springs - Valve Spring Load - Closed - @32.5 mm
          245.0-271.0 N. - Eng Spec.
          •Valve Springs - Valve Spring Load - Open - @32.5 mm
          525.0-575.0 N. - Eng Spec.
            2.2 L61
            Specification
            Metric
            English
            General Data
            •Engine Type
            Inline 4 Cylinder
            •Displacement
            2.2 L
            134 CID
            •RPO
            L61
            •Liter (VIN)
            F
            •Bore
            85.992-86.008 mm
            3.3855-3.3861 in
            •Stroke
            94.6 mm
            3.727 in
            •Compression Ratio
            10.0:1
            Balance Shaft
            •Bearing Clearance
            0.030-0.060 mm
            0.0012-0.0024 in
            20.050-20.063 mm
            0.7894-0.7899 in
            41.975-41.995 mm
            1.6526-1.6534 in
            20.000-20.020 mm
            0.7874-0.7882 in
            •Bushing Clearance
            0.033-0.102 mm
            0.0013-0.0040 in
            36.776-36.825 mm
            1.4479-1.4498 in
            36.723-36.743 mm
            1.4458-1.4466 in
            •End Play
            0.050-0.300 mm
            0.0020-0.0118 in
            Block
            42.000-42.016 mm
            1.6535-1.6542 in
            40.763-40.776 mm
            1.6048-1.6054 in
            64.068-64.082 mm
            2.5224-2.5229 in
            85.992-86.008 mm
            3.3855-3.3861 in
            0.010 mm
            0.0004 in
            0.010 mm
            0.0004 in
            0.030 mm
            0.0012 in
            0.050 mm
            0.002 in
            0.08 mm
            0.0031 in
            Camshaft
            •Camshaft End Play
            0.040-0.144 mm
            0.0016-0.0057 in
            26.935-26.960 mm
            1.0604-1.0614 in
            21.000-21.052 mm
            0.8268-0.8252 in
            Connecting Rod
            0.029-0.073 mm
            0.0011-0.0029 in
            52.118-52.134 mm
            2.0519-2.05252 in
            20.007-20.021 mm
            0.7877-0.7882 in
            0.070-0.370 mm
            0.0028-0.0146 in
            0.021 mm
            0.0083 in
            0.04 mm
            0.0157 in
            Crankshaft
            49.000-49.014 mm
            1.9291-1.9297 in
            0.050-0.380 mm
            0.0012-0.0150 in
            0.031-0.067 mm
            0.0012-0.0026 in
            55.994-56.008 mm
            2.2045-2.2050 in
            Cylinder Head
            •Overall Height, Minimum
            128.9 mm
            5.07 in
            0.030 mm
            0.0012 in
            0.050 mm
            0.002 in
            0.1 mm
            0.004 in
            6.000-6.012 mm
            0.2362-0.2367 in
            6.000-6.012 mm
            0.2362-0.2367 in
            12.013-12.037 mm
            0.4730-0.4739 in
            •Valve Seat Angle - Relief Surface
            30 Degrees
            •Valve Seat Angle - Seating Surface
            45 Degrees
            •Valve Seat Angle - Undercut Surface
            60 Degrees
            •Valve Seat Roundness - Maximum
            0.025 mm
            0.0010 in
            •Valve Seat Runout - Maximum
            0.080 mm
            0.0031 in
            •Valve Seat Width - Exhaust Seating Surface
            1.600 mm
            0.0630 in
            •Valve Seat Width - Intake Seating Surface
            1.200 mm
            0.0472 in
            Lubrication System
            206.84-482.63 kPa
            30-70 psi
            •Oil Capacity
            4.8L
            5.0 quarts
            Piston Rings
            0.20-0.40 mm
            0.008-0.016 in
            0.35-0.55 mm
            0.014-0.022 in
            0.25-0.76 mm
            0.010-0.030 in
            0.04-0.08 mm
            0.0015-0.0031 in
            0.030-0.069 mm
            0.0012-0.0027 in
            0.043-0.192 mm
            0.0017-0.0076 in
            1.170-1.190 mm
            0.0461-0.0469 in
            1.471-1.490 mm
            0.0579-0.0587 in
            0.43 mm
            0.0169 in
            1.574-1.651 mm
            0.0620-0.0650 in
            Pistons and Pins
            0.007-0.026 mm
            0.0003-0.0010 in
            0.002-0.012 mm
            0.0001-0.0005 in
            19.995-20.000 mm
            0.7872-0.7874 in
            0.210-1.266 mm
            0.0083-0.0498 in
            85.967-85.982 mm
            3.3845-3.3851 in
            20.002-20.007 mm
            0.7875-0.7877 in
            •Piston - Piston Ring Groove Width - Top
            1.23-1.25 mm
            0.0484-0.0492 in
            •Piston - Piston Ring Groove Width - Second
            1.52-1.54 mm
            0.0598-0.0606 in
            •Piston - Piston Ring Groove Width - Oil Control
            2.52-2.54 mm
            0.0992-0.1000 in
            0.010-0.041 mm
            0.0004-0.0016 in
            Valve System
            •Valves - Valve Face Angle
            45 Degrees
            0.040 mm
            0.0016 in
            0.080 mm
            0.0031 in
            •Valves - Valve Face Seat Width - Exhaust
            1.6000 mm
            0.06299 in
            •Valves - Valve Face Seat Width - Intake
            1.2000 mm
            0.04724 in
            •Valves - Valve Head Diameter - Exhaust
            29.950-30.250 mm
            1.1791-1.1909 in
            •Valves - Valve Head Diameter - Intake
            34.950-35.250 mm
            1.3760-1.4154 in
            •Valves - Valve Head O.D. and Chamfer Height - Exhaust
            1.1174 mm
            0.04399 in
            •Valves - Valve Head O.D. and Chamfer Height - Intake
            1.0526 mm
            0.04144 in
            5.935-5.950 mm
            0.2337-0.2343 in
            5.955-5.970 mm
            0.2344-0.2355 in
            •Valves - Valve Stem Height - Closed
            32.500 mm
            1.2795 in
            0.050-0.077 mm
            0.0020-0.0026 in
            0.030-0.057 mm
            0.0012-0.0022 in
            •Valve Lash Adjusters - Valve Lash Adjuster Diameter - Stationary Lash Adjuster
            11.986-12.000 mm
            0.0005-0.0020 in
            •Valve Lash Adjusters - Valve Lash-Adjuster-to-Bore Clearance - Stationary Lash Adjuster
            0.013-0.051 mm
            3.2210-3.2299 in
            •Valve Rocker Arms - Rocker Arm Ratio
            1.68 to 1
            •Valve Rocker Arms - Rocker Arm Roller Diameter
            17.740-17.800 mm
            0.6987-0.7008 in
            •Valve Springs - Valve Spring Free Length
            41.400-44.200 mm
            1.6299-1.7402 in
            •Valve Springs - Valve Spring Installed Height - Closed
            32.500 mm
            1.2795 in
            •Valve Springs - Valve Spring Installed Height - Open
            22.500 mm
            0.8858 in
            245.0-271.0 N
            55-61 lb
            •Valve Springs - Valve Spring Load - Open - @22.5 mm
            525.0-575.0 N
            118-129 lb
              2,4 LE5
              Specification
              Metric
              English
              General Data
              •Engine Type
              Inline 4 Cylinder
              •Displacement
              2.4L
              146 CID
              •RPO
              LE5
              •Liter (VIN)
              B
              •Bore
              87.992-88.008 mm
              3.4668-3.4675 in
              •Stroke
              98 mm
              3.861 in
              •Compression Ratio
              10:01
              Balance Shaft
              •Bearing Clearance
              0.030-0.063 mm
              0.0012-0.0025 in
              20.050-20.063 mm
              0.7894-0.7899 in
              41.975-41.995 mm
              1.6526-1.6534 in
              20.000-20.020 mm
              0.7874-0.7882 in
              •Bushing Clearance
              0.033-0.102 mm
              0.0013-0.0040 in
              36.776-36.825 mm
              1.4479-1.4498 in
              36.723-36.743 mm
              1.4458-1.4466 in
              •End Play
              0.100-0.300 mm
              0.0020-0.0118 in
              Block
              42.000-42.016 mm
              1.6535-1.6542 in
              40.763-40.776 mm
              1.6048-1.6054 in
              64.068-64.082 mm
              2.5224-2.5229 in
              87.992-88.008 mm
              3.4668-3.4675 in
              0.010 mm
              0.0004 in
              0.010 mm
              0.0004 in
              0.050 mm
              0.002 in
              0.08 mm
              0.0031 in
              0.030 mm
              0.0012 in
              Camshaft
              •Camshaft End Play
              0.040-0.144 mm
              0.0016-0.0057 in
              26.935-26.960 mm
              1.0604-1.0614 in
              21.000-21.052 mm
              0.8268-0.8252 in
              Connecting Rod
              0.029-0.069 mm
              0.0011-0.0027 in
              52.118-52.134 mm
              2.0519-2.05252 in
              20.007-20.021 mm
              0.7877-0.7882 in
              0.070-0.370 mm
              0.0028-0.0146 in
              0.021 mm
              0.0083 in
              0.04 mm
              0.0157 in
              Crankshaft
              49.000-49.014 mm
              1.9291-1.9297 in
              0.050-0.380 mm
              0.0012-0.0150 in
              0.031-0.067 mm
              0.0012-0.0026 in
              55.994-56.008 mm
              2.2045-2.2050 in
              Cylinder Head
              0.050 mm
              0.002 in
              0.1 mm
              0.004 in
              0.030 mm
              0.0012 in
              6.000-6.012 mm
              0.2362-0.2367 in
              6.000-6.012 mm
              0.2362-0.2367 in
              12.013-12.037 mm
              0.4730-0.4739 in
              30 Degrees
              45 Degrees
              60 Degrees
              0.025 mm
              0.0010 in
              0.080 mm
              0.0031 in
              1.600 mm
              0.0630 in
              1.200 mm
              0.0472 in
              Lubrication System
              344.75-551.60 kPa
              50-80 psi
              •Oil Capacity
              4.8L
              5.0 quarts
              Piston Rings
              0.20-0.40 mm
              0.008-0.016 in
              0.35-0.55 mm
              0.014-0.022 in
              0.25-0.76 mm
              0.010-0.030 in
              0.04-0.08 mm
              0.0015-0.0031 in
              0.030-0.069 mm
              0.0012-0.0027 in
              0.090-0.106 mm
              0.0035-0.0042 in
              1.170-1.190 mm
              0.0461-0.0469 in
              1.471-1.490 mm
              0.0579-0.0587 in
              0.43 mm
              0.0169 in
              1.574-1.651 mm
              0.0620-0.0650 in
              Pistons and Pins
              0.007-0.026 mm
              0.0003-0.0010 in
              0.002-0.012 mm
              0.0001-0.0005 in
              19.995-20.000 mm
              0.7872-0.7874 in
              0.19-1.16 mm
              0.0075-0.0461 in
              85.967-85.982 mm
              3.3845-3.3851 in
              20.002-20.007 mm
              0.07875-0.7877 in
              1.23-1.25 mm
              0.0484-0.0492 in
              1.52-1.54 mm
              0.0598-0.0606 in
              2.52-2.54 mm
              0.0992-0.1000 in
              0.010-0.041 mm
              0.0004-0.0016 in
              Valve System
              45 Degrees
              0.040 mm
              0.0016 in
              0.080 mm
              0.0031 in
              1.6000 mm
              0.06299 in
              1.2000 mm
              0.04724 in
              29.950-30.250 mm
              1.1791-1.1909 in
              34.950-35.250 mm
              1.3760-1.4154 in
              1.1174 mm
              0.04399 in
              1.0526 mm
              0.04144 in
              5.935-5.950 mm
              0.2337-0.2343 in
              5.955-5.970 mm
              0.2344-0.2355 in
              32.500 mm
              1.2795 in
              0.030-0.057 mm
              0.0012-0.0022 in
              0.050-0.077 mm
              0.0020-0.0026 in
              11.986-12.000 mm
              0.0005-0.0020 in
              0.013-0.051 mm
              3.2210-3.2299 in
              1.68 to 1
              17.740-17.800 mm
              0.6987-0.7008 in
              41.400-44.200 mm
              1.6299-1.7402 in
              32.500 mm
              1.2795 in
              22.500 mm
              0.8858 in
              245.0-271.0 N
              55-61 lb
              525.0-575.0 N
              118-129 lb
                3.0 L81
                Engine Block Specifications Application
                Service Limit
                Metric
                English
                Cylinder Bore - Select Fit Designation Stamped on Block
                85.975-85.985 mm
                3.3848-3.3852 in
                •(99)
                85.985-85.995 mm
                3.3852-3.3856 in
                •(00)
                85.995-86.005 mm
                3.3856-3.3860 in
                •(01)
                86.005-86.015 mm
                3.3860-3.3864 in
                •(02)
                86.015-86.025 mm
                3.3864-3.3868 in
                •(7 + 0.5) Oversize
                86.465-86.475 mm
                3.4041-3.4045 in
                •Maximum Out-of-Round
                0.065 mm
                0.0003 in
                •Taper
                0.0065 mm
                0.0003 in
                Piston - Select Fit Designation Stamped on Top of Piston
                85.940-85.950 mm
                3.3834-3.3838 in
                •(99)
                85.950-85.960 mm
                3.3838-3.3842 in
                •(00)
                85.960-85.970 mm
                3.3842-3.3846 in
                •(01)
                85.970-85.980 mm
                3.3846-3.3850 in
                •(02)
                85.980-85.990 mm
                3.3850-3.3854 in
                •(7 + 0.5) Oversize
                86.430-86.440 mm
                3.4027-3.4031 in
                •Piston Bore Clearance
                0.025-0.045 mm
                0.0010-0.0018 in
                •Piston Pin Diameter
                21 mm
                0.8267 in
                •Clearance in Piston
                0.003-0.008 mm
                0.0001-0.0003 in
                Piston Ring - Compression
                •Thickness
                1.5 mm
                0.0590 in
                •Ring Groove Clearance
                0.02-0.04 mm
                0.0008-0.0015 in
                •Ring Gap
                0.30-0.50 mm
                0.0118-0.0196 in
                Piston Ring - Oil
                •Thickness
                3.0 mm
                0.1181 in
                0.01-0.03 mm
                0.0004-0.0012 in
                •Ring Gap
                0.40-1.40 mm
                0.0157-0.0551 in
                Piston Pin
                •Diameter
                21 mm
                0.8267 in
                0.001-0.015 mm
                0.0001-0.0003 in
                Crankshaft - Main Journal
                •Standard Size - Green
                67.980-67.988 mm
                2.6763-2.6766 in
                •Standard Size - Brown
                67.988-67.996 mm
                2.6766-2.6770 in
                •Undersize - 0.25 - Green/Blue
                67.730-67.738 mm
                2.6656-2.6668 in
                •Undersize - 0.25 - Brown/Blue
                67.738-67.746 mm
                2.668-2.6671 in
                •Undersize - 0.50 - Green/White
                67.480-67.488 mm
                2.666-2.6570 in
                •Undersize - 0.50 - Brown/Blue
                67.488-67.496 mm
                2.6570-2.6573 in
                •Main Journal Maximum Out-of-Round
                0.03 mm
                0.0012 in
                •Crankshaft Bearing Clearance
                0.014-0.043 mm
                0.0006-0.0017 in
                0.010-0.76 mm
                0.0004-0.0300 in
                48.971-48.990 mm
                1.927-1.928 in
                •Undersize - 0.25
                48.721-48.740 mm
                1.918-1.919 in
                •Undersize - 0.50
                48.471-48.490 mm
                1.908-1.909 in
                Connecting Rod
                •Side Clearance
                0.07-0.28 mm
                0.0027-0.0110 in
                •Bearing Clearance
                0.013-0.061 mm
                0.0005-0.0024 in
                •Big End Diameter
                52.000-52.012 mm
                2.0472-2.0477 mm
                Cylinder Head Specifications Measurement
                Standard
                Service Limit
                Metric
                English
                Metric
                English
                Compression (Hot)
                1310 kPa
                190 psi min
                1,241 kPa
                180 psi min
                69 kPa 10% max
                10 psi max
                138 kPa 15% max
                20 psi max
                Cylinder Head
                Total Height
                134.0 mm
                5.276 in
                133.9-134.1 mm
                5.272-5.280 in
                Maximum Distortion (Length)
                0.05/100 mm
                0.0020/3.937 in
                Valve
                Lifter
                Face Angle
                45 degrees
                Seat Angle
                45 degrees
                Seat Width
                Intake
                1.0-1.4 mm
                0.0394-0.0551 in
                Exhaust
                1.4-1.8 mm
                0.0551-0.0709 in
                Valve Length - Production
                Intake
                102.1 mm
                4.016 in
                Exhaust
                92.25 mm
                3.632 in
                Valve Length - Service
                Intake
                101.7 mm
                4.0039 in
                Exhaust
                91.8 mm
                3.6141 in
                Valve Stem Diameter
                Standard (K) Intake
                5.955-5.970 mm
                0.2344-0.2350 in
                Standard (K) Exhaust
                5.945-5.960 mm
                0.2341-0.2346 in
                Oversize (K 1-0.075) Intake
                6.030 mm
                0.2374 in
                Oversize (K 1-0.075) Exhaust
                6.020 mm
                0.2370 in
                Valve Guide Diameter
                Standard (K)
                6.000-6.012 mm
                0.2362-0.2367 in
                6.075-6.090 mm
                0.2392-0.2398 in
                Valve Guide Installed Height
                13.7-14.0 mm
                0.5394-0.5512 in
                Stem Clearance
                Intake
                0.030-0.057 mm
                0.0012-0.0022 in
                Exhaust
                0.040-0.067 mm
                0.0016-0.0026 in
                Valve Height
                Intake
                39.2 mm
                1.543 in
                Exhaust
                39.2 mm
                1.543 in
                Intake and Exhaust Compressed at 252 N (56.6 lbs)
                34 mm
                1.338 in
                Camshaft
                8.66-8.74 mm
                0.3409-0.344 in
                8.61 mm
                0.339 in min
                32.959-32.975 mm
                1.2976-1.282 in
                32.947 mm
                1.297 in min
                0.025-0.066 mm
                0.0010-0.0026 in
                0.083 mm
                0.003 in max
                Journal Diameter
                27.939-27.960 mm
                1.099-1.101 in
                Bearing Clearance
                0.040-0.082 mm
                0.0015-0.0020 in
                End Play
                0.04-0.144 mm
                0.0016-0.0057 in
                Spark Plug
                Type
                Bosch FLR-LTE, GM
                P/N 90541059
                Gap
                0.9-1.1 mm
                0.035-0.043 in
                Torque
                25 N·m
                19 lb ft
                Engine Idle - at Normal Operating Temperature
                110 kPa
                16 psi
                  3.5 L66 (honda)
                  Application
                  Specification
                  Metric
                  English
                  General
                  •Engine Type
                  Water Cooled, 4-Stroke, SOHC Gasoline Engine
                  •Displacement
                  3471 cc
                  212 cu in
                  •RPO
                  L66
                  •VIN
                  U
                  •Cylinder Arrangement
                  60° V6 Transverse
                  •Bore
                  89.0 mm
                  3.50 in
                  •Stroke
                  93.0 mm
                  3.66 in
                  •Compression Ratio
                  10.0:1
                  •Engine Compression Test - Minimum
                  990 kPa
                  145 psi
                  •Engine Compression Test - Maximum Variation
                  200 kPa
                  29 psi
                  •Idle Speed
                  680-780 RPM
                  •Firing Order
                  1-4-2-5-3-6
                  •Spark Plug Gap - Production
                  1.0-1.1 mm
                  0.039-0.043 in
                  •Spark Plug Gap - Service
                  1.3 mm
                  0.051 in
                  •Ignition Timing
                  8-12 BTDC at 680-780 RPM
                  Block
                  77.0-77.024 mm
                  3.031-3.032 in
                  •Cylinder Bore Diameter - Production
                  89.0-89.015 mm
                  3.5039-3.5045 in
                  •Cylinder Bore Diameter - Service
                  89.065 mm
                  3.5065 in
                  •Cylinder Bore Diameter - 0.25 mm (0.0098 in) Oversize Piston
                  89.25-89.265 mm
                  3.5138-3.5144 in
                  •Cylinder Bore Taper - Service
                  0.05 mm
                  0.002 in
                  •Cylinder Head Deck Surface Flatness - Production
                  0.07 mm
                  0.003 in
                  •Cylinder Head Deck Surface Flatness - Service
                  0.1 mm
                  0.004 in
                  •Cylinder Reboring Limit - Service
                  0.25 mm
                  0.01 in
                  •Rear Housing-to-Oil Seal Clearance
                  0.5-0.8 mm
                  0.019-0.031 in
                  Camshaft
                  •Camshaft-to-Cap Clearance - Production
                  0.05-0.2 mm
                  0.002-0.008 in
                  •Camshaft-to-Cap Clearance - Service
                  0.2 mm
                  0.008 in
                  •End Play - Production
                  0.05-0.20 mm
                  0.002-0.008 in
                  •End Play - Service
                  0.2 mm
                  0.008 in
                  •Journal Diameter
                  42.935-42.950 mm
                  1.690-1.691 in
                  •Journal Out-of-Round - Maximum
                  0.03 mm
                  0.0012 in
                  •Camshaft-to-Journal Clearance - Production
                  0.05-0.089 mm
                  0.002-0.0035 in
                  •Camshaft-to-Journal Clearance - Service
                  0.15 mm
                  0.006 in
                  •Lobe Height - Intake Primary
                  35.041 mm
                  1.3796 in
                  •Lobe Height - Intake Mid
                  36.445 mm
                  1.4348 in
                  •Lobe Height - Intake Secondary
                  35.284 mm
                  1.3891 in
                  •Lobe Height - Exhaust
                  36.326 mm
                  1.4302 in
                  •Lobe Lift - Intake Primary
                  5.041 mm
                  0.1984 in
                  •Lobe Lift - Intake Mid
                  6.323 mm
                  0.2489 in
                  •Lobe Lift - Intake Secondary
                  5.284 mm
                  0.2080 in
                  •Lobe Lift - Exhaust
                  6.326 mm
                  0.2490 in
                  •Runout - Production
                  0.03 mm
                  0.001 in
                  •Runout - Service
                  0.04 mm
                  0.002 in
                  Cooling System
                  •Thermostat Begins-to-Open Temperature
                  76-80°C
                  168-176°F
                  •Thermostat Full Open Temperature
                  90°C
                  194°F
                  •Water Pump Displacement - at 6,000 RPM Per Minute
                  176 liters
                  186 qts
                  Connecting Rod
                  •Bearing Clearance - Production
                  0.02-0.044 mm
                  0.0008-0.0017 in
                  •Bearing Clearance - Service
                  0.05 mm
                  0.002 in
                  •Bore Diameter - Bearing End
                  58 mm
                  2.28 in
                  •Bore Diameter - Pin End
                  21.97-21.976 mm
                  0.865-0.8652 in
                  •Bore Out-of-Round - Bearing End
                  0.005 mm
                  0.0002 in
                  •Length
                  158.5 mm
                  6.24 in
                  0.15-0.35 mm
                  0.006-0.014 in
                  •End Play - Service
                  0.45 mm
                  0.018 in
                  •Connecting Rod Bolt - Difference in Diameter - Service
                  0.0-0.1 mm
                  0.0-0.004 in
                  Crankshaft
                  54.976-55.0 mm
                  2.1644-2.1654 in
                  •Connecting Rod Journal Out-of-Round - Production
                  0.005 mm
                  0.0002 in
                  •Connecting Rod Journal Out-of-Round - Service
                  0.01 mm
                  0.0004 in
                  •Connecting Rod Journal Taper - Production
                  0.005 mm
                  0.0002 in
                  •Connecting Rod Journal Taper - Service
                  0.01 mm
                  0.0004 in
                  •Connecting Rod Journal Width
                  17.55-17.75 mm
                  0.691-0.699 in
                  0.1-0.35 mm
                  0.004-0.014 in
                  •End Play - Service
                  0.45 mm
                  0.018 in
                  •Main Bearing Clearance - Production
                  0.02-0.044 mm
                  0.0008-0.0017 in
                  •Main Bearing Clearance - Service
                  0.05 mm
                  0.002 in
                  •Main Journal Diameter
                  71.976-72.0 mm
                  2.8337-2.8346 in
                  •Main Journal Out-of-Round - Production
                  0.005 mm
                  0.0002 in
                  •Main Journal Out-of-Round - Service
                  0.01 mm
                  0.0004 in
                  •Main Journal Taper - Production
                  0.005 mm
                  0.0002 in
                  •Main Journal Taper - Service
                  0.01 mm
                  0.0004 in
                  •Runout - Production - Journals 1 and 4
                  0.02 mm
                  0.0008 in
                  •Runout - Production - Journals 2 and 3
                  0.025 mm
                  0.001 in
                  •Runout - Service
                  0.03 mm
                  0.0012 in
                  •Thrust Surface Distance
                  0.1-0.35 mm
                  0.004-0.014 in
                  •Thrust Surface Runout
                  0.45 mm
                  0.018 in
                  Cylinder Head
                  •Combustion Chamber Volume
                  51.3 cu cm
                  3.13 cu in
                  120.95-121.05 mm
                  4.762-4.766 in
                  0.05 mm
                  0.002 in
                  •Surface Flatness - Exhaust Manifold Deck
                  0.05 mm
                  0.002 in
                  •Surface Flatness - Intake Manifold Deck
                  0.05 mm
                  0.002 in
                  •Resurface Limit - Block Deck
                  0.2 mm
                  0.008 in
                  •Valve Guide Bore - Exhaust - Production
                  5.515-5.53 mm
                  0.2171-0.2178 in
                  •Valve Guide Bore - Exhaust - Service
                  5.55 mm
                  0.219 in
                  •Valve Guide Bore - Intake - Production
                  5.515-5.530 mm
                  0.2171-0.2177 in
                  •Valve Guide Bore - Intake - Service
                  5.55 mm
                  0.219 in
                  •Valve Guide Installed Height - Exhaust
                  20.63-21.63 mm
                  0.812-0.852 in
                  •Valve Guide Installed Height - Intake
                  21.2-22.2 mm
                  0.835-0.874 in
                  Lubrication System
                  •Oil Type
                  5W-20
                  •Oil Capacity - with Engine Overhaul
                  5.0 liters
                  5.2 qts
                  4.3 liters
                  4.5 qts
                  •Oil Capacity - without Filter
                  4.0 liters
                  4.2 qts
                  •Oil Pressure - at Idle and Engine at 80°C (176°F)
                  70 kPa
                  10 psi
                  •Oil Pressure - at 3,000 RPM and Engine at 80°C (176°F)
                  490 kPa
                  71 psi
                  Oil Pump
                  •Displacement - at 6,000 RPM Per Minute
                  58.4 liters
                  61.7 qts
                  •Rotor Diameter - Outer
                  84 mm
                  3.307 in
                  •Rotor Pocket - Depth - Inner
                  12.72 mm
                  0.5 in
                  •Rotor Pocket - Depth - Outer
                  12.78 mm
                  0.503 in
                  •Inner Rotor-to-Outer Rotor Radial Clearance - New
                  0.04-0.16 mm
                  0.002-0.0063 in
                  •Inner Rotor-to-Outer Rotor Radial Clearance - Service Limit
                  0.2 mm
                  0.008 in
                  •Housing-to-Rotor Axial Clearance - New
                  0.02-0.07 mm
                  0.001-0.003 in
                  •Housing-to-Rotor Axial Clearance - Service Limit
                  0.12 mm
                  0.005 in
                  •Housing-to-Outer Rotor Radial Clearance - New
                  0.10-0.19 mm
                  0.004-0.007 in
                  •Housing-to-Outer Rotor Radial Clearance - Service Limit
                  0.2 mm
                  0.008 in
                  Piston Rings
                  •End Gap - Top - Production
                  0.2-0.35 mm
                  0.008-0.014 in
                  •End Gap - Top - Service
                  0.6 mm
                  0.024 in
                  •End Gap - Second - Production
                  0.4-0.55 mm
                  0.0016-0.022 in
                  •End Gap - Second - Service
                  0.7 mm
                  0.028 in
                  •End Gap - Oil - Production
                  0.2-0.7 mm
                  0.008-0.028 in
                  •End Gap - Oil - Service
                  0.8 mm
                  0.031 in
                  •First Compression Ring - Production
                  0.02-0.35 mm
                  0.008-0.014 in
                  •First Compression Ring - Service
                  0.6 mm
                  0.024 in
                  •Second Compression Ring - Production
                  0.4-0.055 mm
                  0.0016-0.0022 in
                  •Second Compression Ring - Service
                  0.7 mm
                  0.028 in
                  •Oil Control Ring - Production
                  0.2-0.7 mm
                  0.008-0.028 in
                  •Oil Control Ring - Service
                  0.8 mm
                  0.031 in
                  •Piston Ring-to-Groove Clearance - Top - Production
                  0.055-0.08 mm
                  0.0022-0.0031 in
                  •Piston Ring-to-Groove Clearance - Top - Service
                  0.15 mm
                  0.006 in
                  •Piston Ring-to-Groove Clearance - Second - Production
                  0.03-0.055 mm
                  0.0012-0.0022 in
                  •Piston Ring-to-Groove Clearance - Second - Service
                  0.13 mm
                  0.005 in
                  0.055-0.08 mm
                  0.0022-0.0031 in
                  0.13 mm
                  0.005 in
                  0.03-0.055 mm
                  0.0012-0.0022 in
                  0.13 mm
                  0.005 in
                  •First Compression Ring Height
                  1.2 mm
                  0.05 in
                  •First Compression Width
                  3.1 mm
                  0.12 in
                  •Second Compression Height
                  1.2 mm
                  0.05 in
                  •Second Compression Width
                  3.4 mm
                  0.13 in
                  Pistons
                  •Diameter - Production - Measure 16 mm (0.63 in) from Bottom of Skirt
                  88.975-88.985 mm
                  3.5029-3.5033 in
                  •Diameter - Service
                  88.965 mm
                  3.5026 in
                  •Diameter - 0.25 mm Oversize Piston
                  89.225-89.235 mm
                  3.5128-3.5132 in
                  •Out-of-Round - Measured by Clearance to Cylinder Bore
                  0.08 mm
                  3.15 in
                  •Pin Bore Diameter
                  21.96-22.03 mm
                  0.864-0.867 in
                  •Ring Groove Width - Top - Production
                  1.24-1.25 mm
                  0.0488-0.0492 in
                  •Ring Groove Width - Top - Service
                  1.27 mm
                  0.05 in
                  •Ring Groove Width - Second - Production
                  1.22-1.23 mm
                  0.048-0.0484 in
                  •Ring Groove Width - Second - Service
                  1.25 mm
                  0.049 in
                  •Ring Groove Width - Oil - Production
                  2.805-2.825 mm
                  0.1104-0.1112 in
                  •Ring Groove Width - Oil - Service
                  2.85 mm
                  0.112 in
                  •Piston to Bore Clearance - Production
                  0.015-0.04 mm
                  0.0006-0.0016 in
                  •Piston to Bore Clearance - Service
                  0.08 mm
                  0.003 in
                  Piston Pin
                  •Clearance to Connecting Rod Bore - Production
                  0.005-0.014 mm
                  0.0002-0.0006 in
                  •Clearance to Connecting Rod Bore - Service
                  0.019 mm
                  0.0007 in
                  •Clearance to Piston Pin Bore - Production
                  -0.005 to +0.001 mm
                  -0.0002 to +0.00004 in
                  •Clearance to Piston Pin Bore - Service
                  0.004 mm
                  0.0002 in
                  21.962-21.965 mm
                  0.8646-0.8648 in
                  •Diameter - Service
                  21.954 mm
                  0.8643 in
                  •Length
                  53.77-54.23 mm
                  2.116-2.135 in
                  Starter
                  •Rated Output
                  1.6 kW
                  2.15 hp
                  Timing Belt Tensioner
                  •Tensioner Rod Extended
                  48.8-58.7 mm
                  1.92-2.31 in
                  •Tensioner Spring Load - Rod Extended
                  151 N at 58.7 mm
                  34 lb at 2.31 in
                  •Tensioner Spring Load - Rod Partially Extended
                  185 N at 54.4 mm
                  41.5 lb at 2.14 in
                  •Tensioner Spring Load - Rod Retracted
                  228 N at 48.8 mm
                  51 lb at 1.92 in
                  Valves and Valve Seats
                  •Clearance - Cold - Exhaust
                  0.28-0.32 mm
                  0.011-0.013 in
                  •Clearance - Cold - Intake
                  0.20-0.24 mm
                  0.008-0.009 in
                  •Face Angle - Exhaust
                  40-60 degrees
                  •Face Angle - Intake
                  45-60-70 degrees
                  •Face Runout - Maximum
                  0.04 mm
                  0.0016 in
                  •Face Width
                  2.121 mm
                  0.083 in
                  •Head Diameter - Exhaust
                  29.9-30.1 mm
                  1.177-1.185 in
                  •Head Diameter - Intake
                  34.9-35.1 mm
                  1.374-1.382 in
                  •Key Groove Diameter
                  4.595-4.60 mm
                  0.180-0.181 in
                  •Length - Exhaust
                  113.9-114.5 mm
                  4.484-4.508 in
                  •Length - Intake
                  115.7-116.3 mm
                  4.555-4.579 in
                  •Seat Angle - Exhaust
                  30-45-60 degrees
                  •Seat Angle - Intake
                  30-45-67 degrees
                  •Seat Width - Exhaust - Production
                  1.25-1.55 mm
                  0.049-0.061 in
                  •Seat Width - Exhaust - Service
                  2.0 mm
                  0.079 in
                  •Seat Width - Intake - Production
                  1.25-1.55 mm
                  0.049-0.061 mm
                  •Seat Width - Intake - Service
                  2.0 mm
                  0.079 in
                  •Stem Diameter - Exhaust - Production
                  5.45-5.46 mm
                  0.2146-0.215 in
                  •Stem Diameter - Exhaust - Service
                  5.42 mm
                  0.2134 in
                  •Stem Diameter - Intake - Production
                  5.485-5.495 mm
                  0.2159-0.2163 in
                  •Stem Diameter - Intake - Service
                  5.455 mm
                  0.2148 in
                  •Stem Installed Height - Exhaust - Production
                  46.68-47.48 mm
                  1.838-1.869 in
                  •Stem Installed Height - Exhaust - Service
                  47.73 mm
                  1.879 in
                  •Stem Installed Height - Intake - Production
                  46.75-47.55 mm
                  1.841-1.872 in
                  •Stem Installed Height - Intake - Service
                  47.8 mm
                  1.882 in
                  •Stem-to-Guide Clearance - Exhaust - Production
                  0.055-0.08 mm
                  0.0022-0.0031 in
                  •Stem-to-Guide Clearance - Exhaust - Service
                  0.11 mm
                  0.004 in
                  •Stem-to-Guide Clearance - Intake - Production
                  0.02-0.045 mm
                  0.0008-0.0018 in
                  •Stem-to-Guide Clearance - Intake - Service
                  0.08 mm
                  0.003 in
                  Valve Guides
                  21.20-22.2 mm
                  0.835-0.874 in
                  20.63-21.63 mm
                  0.812-0.852 in
                  Valve Lash Adjuster
                  •Free Length
                  47.41 mm
                  1.87 in
                  •Spring Load
                  49 N at 45.5 mm
                  11 lb at 1.79 in
                  Rocker Arms and Shafts
                  •Bore Diameter
                  20.02-20.05 mm
                  0.788-0.789 in
                  •Arm-to-Shaft Clearance - Exhaust - Production
                  0.026-0.077 mm
                  0.001-0.003 in
                  •Arm-to-Shaft Clearance - Exhaust - Service
                  0.077 mm
                  0.003 in
                  •Arm-to-Shaft Clearance - Intake - Production
                  0.026-0.067 mm
                  0.001-0.0026 in
                  •Arm-to-Shaft Clearance - Intake - Service
                  0.067 mm
                  0.0026 in
                  •Ratio
                  1.5:1
                  •Shaft Diameter
                  20.0 mm
                  0.7874 in
                  •Intake Rocker Arm Test - Regulator Pressure Setting
                  440-540 kPa
                  64-78 psi
                  Valve Springs
                  •Coil Thickness - Exhaust
                  3.5 mm
                  0.137 in
                  •Coil Thickness - Intake
                  3.6 mm
                  0.141 in
                  •Diameter - Inside
                  16.2 mm
                  0.637 in
                  •Diameter - Outside - Exhaust
                  23.2 mm
                  0.913 in
                  •Diameter - Outside - Intake
                  23.4 mm
                  0.921 in
                  •Free Length - Exhaust
                  51.06 mm
                  2.01 in
                  •Free Length - Intake
                  51.54 mm
                  2.029 in
                  •Installed Height
                  43.4 mm
                  1.708 in
                    Torque Specs
                    Originally posted by Slow97SL1
                    Saturn Torque Specs
                    All numbers are Torque Ft/Lbs unless noted.
                    These numbers are thought to be correct but always double check.
                    91/92 Models
                    A/C Compressor Bracket to Engine Bolts 19
                    A/C Compressor to Front Bracket Bolt 40
                    A/C Compressor to Rear Bracket Bolt 19
                    Accessory Belt Idler Bolts 33
                    Accessory Belt Tensioner Bolts 22
                    Axle Shaft Support Bracket to Engine Bolts 41
                    Camshaft Sprocket Bolt 75
                    Connecting Rod Cap Nut 33
                    Cradle to Body Bolts 151
                    Crankshaft Sprocket Bolt 158
                    Cylinder Head Bolt
                    DOHC Tighten all bolts in sequence to 22ft/lbs. Then tighten all bolts to 37ft/lbs. Repeat sequence, tightening all bolts an additional 1/4 turn.
                    SOHC Tighten all bolts in sequence to 22ft/lbs. Then tighten all bolts to 33ft/lbs. Repeat sequence, tightening all bolts an additional 1/4 turn.
                    Engine Block Drain Plug 26
                    Engine to Transaxle Stiffening Brackets 40
                    Exhaust Manifold Retaining Nuts
                    DOHC 23
                    SOHC 16
                    Exhaust Pipe to Manifold Nuts 23
                    Flex Plate to Crankshaft 44
                    Flex plate to Torque Converter Bolts 41
                    Flywheel to Crankshaft 59
                    Front Engine Mount 52
                    Front Pulley to Crankshaft Bolt 159
                    Front Strut to Knuckle Bolt 148
                    Fuel Lines 19
                    Intake Manifold Retaining Nuts 22
                    Intake Manifold Support Bracket to Engine Bolt
                    DOHC
                    LH Side 22
                    RH Side 41
                    SOHC 22
                    Main Bearing Cap Bolts 37
                    Oil Pan Dran Plug 26
                    Power Steering Pump Retaining Bolts 27
                    Rocker Arm Shaft Bolts 19
                    Starter Motor Retaining Bolts 27
                    Throttle Body Bolts 23
                    Timing Chain Guide Bolts
                    Fixed 21
                    Pivoting 19
                    Torque Axis Mount to Engine Nuts 52
                    Torque Strut to Cradle Brackets 52
                    Transaxle to Block Bolts
                    Lower 96
                    Upper 66
                    Water Pump to Block Bolts 22
                    Water Pump Pulley Bolts 19
                    Wheel Lug Nuts 103
                    Cam Cover Bolts 89
                    Camshaft Bearing Cap Bolt 124
                    Coolant Sensor 71
                    Crankshaft Seal Housing to Block Bolts 97
                    Front Cover Bolts
                    Lower Center Bolt 89
                    Perimeter and Upper Center 22
                    Fuel Line to Fuel Rail 133
                    Fuel Line to Fuel Pressure Regulator 133
                    Oil Pan Bolts 80
                    Oil Pump Cover Screws 97
                    Starter Motor Bracket 80
                    Timing Chain Tensioner Bolts 168
                    93-97 Models
                    Crankshaft Pulley/Balancer Bolt 159
                    Cylinder Head Bolt
                    Engine Mounts
                    Front Mount to Block 52
                    Rear Mounts 35
                    DOHC 23
                    SOHC 16
                    Front Cover
                    Except Lower Center Bolt 22
                    DOHC 22
                    SOHC 15
                    Oil Pan Darn Plug 26
                    Strut to Steering Knuckle Bolt 148
                    Throttle Body Bolts 24
                    Timing Chain Guide Bolts 19
                    Timing Chain Tensioner Bolt 14
                    Torque Axis Mount to Engine Nuts 37
                    Lower 96
                    Upper 66
                    Wheel Lug Nuts 103
                    Cam Cover Bolt 89
                    Front Cover Lower Bolt 89
                    Fuel Line to Fuel Pressure Regulator Nut 133
                    Oil Pan Bolts 80
                    98-01 Models
                    Accessory Belt Idler Bolts 22
                    Clutch Pressure Plate 19
                    Cylinder Head Bolt
                    Engine Mounts
                    Front Mount to Front Cover 37
                    Rear Mounts 35
                    DOHC 150 Inch/Lbs
                    SOHC 16
                    Flex plate to Torque Converter Bolts 52
                    Front Cover
                    Lower Center Bolt 89 Inch/lbs
                    Oil Pan Drain Plug 27
                    Power Steering Pump Retaining Bolts 22
                    Spark Plugs 20
                    Lower 96
                    Upper 66
                    Wheel Lug Nuts 103
                    Camshaft Bearing Cap Bolt 124 INCH lbs or 8 ft/lbs
                    Cylinder Head Cover Bolt 89
                    Oil Pan Bolts 80
                    Um, 98 Is the Last year for the 91-98 style shorter rods that use nuts for the connecting rods, after 98 they use BOLTS
                    Connecting Rod Cap-to-Rod,25 N•m+75°,19 lb ft+75°.
                    2k2 torque specs
                    Complete 2002 Engine Fastener Specs - FSM source
                    Fastener Tightening Specifications
                    Application Specification,Metric,English
                    A/C Compressor Brackets-to-Head/Block,25 N•m,19 lb ft
                    A/C Compressor-to-Front Bracket,54 N•m,40 lb ft
                    A/C Compressor-to-Rear Bracket,25 N•m,19 lb ft
                    A/C Compressor-to-Rear Bracket,30 N•m,22 lb ft
                    Accelerator Control Cable Bracket-to-Intake Manifold (L24),30 N•m,22 lb ft
                    Axle Shaft Intermediate Bracket-to-Block,55 N•m,41 lb ft
                    Battery Hold Down Nut,9 N•m,80 lb in
                    Battery Terminal Bolts,17 N•m,13 lb ft
                    Belt Idler Pulley-to-Front Cover,27 N•m,20 lb ft
                    Belt Tensioner Idler Pulley Bolt,27 N•m,20 lb ft
                    Belt Tensioner-to-Block,30 N•m,22 lb ft
                    Belt Tensioner-to-Front Cover,27 N•m,20 lb ft
                    Brake Caliper Bolt,110 N•m,81 lb ft
                    Camshaft Bearing Cap-to-Head (LL0),14 N•m,10 lb ft
                    Camshaft Cover-to-Head (LL0),10 N•m,89 lb in
                    Camshaft Sprockets-to-Camshafts,100 N•m,74 lb ft
                    Camshaft Thrust Bearing-to-Head (L24),25 N•m,19 lb ft
                    Canister Purge Solenoid-to-Block,22 N•m,16 lb ft
                    Clutch Pressure Plate-to-Flywheel,25 N•m,19 lb ft
                    Coolant Drain-to-Plug/Block,30 N•m,22 lb ft
                    Coolant Temperature Sensor,8 N•m,71 lb in
                      Continued.
                      Crankshaft Bearing Cap-to-Block,50 N•m,37 lb ft
                      Crankshaft Bearing Tie Plates,25 N•m,18 lb ft
                      Crankshaft Bearing Tie Plate Insert,3.5 N•m,31 lb in
                      Crankshaft Bearing Tie Plate-to-Oil Pan Rail,55 N•m,41 lb ft
                      Crankshaft Position Sensor,9 N•m,80 lb in
                      Crankshaft Pulley Bolt (L24),215 N•m,159 lb ft
                      Crankshaft Rear Oil Seal Assembly-to-Block,11 N•m,97 lb in
                      Crankshaft Vibration Damper/Pulley-to-Crankshaft,215N•m,159 lb ft
                      Cylinder Block Drain Plugs,35 N•m,26 lb ft
                      Cylinder Head Bolts - First Pass,30 Cylinder Head Bolt Tightening Sequence,22 Cylinder Head Bolt Tightening Sequence
                      Cylinder Head Bolts - First Pass,30 N•m,22 lb ft
                      Cylinder Head Bolts - Second Pass (DOHC),45 N•m+90°,33 lb ft+90°
                      Cylinder Head Bolts - Second Pass (SOHC),50 N•m+90°,37 lb ft+90°
                      Deaeration Line Clamps-to-Engine Bracket (L24),11 N•m,97 lb in
                      Deaeration Line Fitting-to-Cylinder Head (L24),9 N•m,80 lb in
                      EGR Valve-to-Head,30 N•m,22 lb ft
                      EGR Valve-to-Head,25 N•m,19 lb ft
                      Engine Block Heater Bolt,25 N•m,18 lb ft
                      Engine Mount-to-Front Cover Nuts,50 N•m,37 lb ft
                      Engine Mount-to-Midrail Bracket Nuts,50 N•m,37 lb ft
                      Engine Stiffening Bracket,47 N•m,35 lb ft
                      Engine Strut-to-Frame Bracket and Engine Strut-to-Engine Bracket,70 N•m,52 lb ft
                      Engine/Transaxle Grounds,25 N•m,19 lb ft
                      Exhaust Manifold Studs-to-Head,13 N•m,9.5 lb ft
                      Exhaust Manifold-to-Head (L24),22 N•m,16 lb ft
                      Exhaust Manifold-to-Head (LL0),18 N•m,13 lb ft
                      Exhaust Pipe Bracket to Stiffener Bracket,47 N•m,35 lb ft
                      Exhaust Pipe to Catalytic Converter,48 N•m,35 lb ft
                      Exhaust Pipe to Manifold,31 N•m,23 lb ft
                      Exhaust Pipe to Support Bracket,31 N•m,23 lb ft
                      Flexplate-to-Converter,70 N•m,52 lb ft
                      Flexplate-to-Crankshaft,60 N•m,44 lb ft
                      Flywheel-to-Crankshaft,80 N•m,59 lb ft
                      Frame-to-Body,205 N•m,151 lb ft
                      Front A/C Bracket-to-Block,47 N•m,35 lb ft
                      Front Cover Lower Center Bolt (Number 14),10 N•m,89 lb in
                      Front Cover Perimeter Bolts,30 N•m,22 lb ft
                      Front Mount-to-Engine Block,55 N•m,41 lb ft
                      Fuel Line Retainer Clip,4 N•m,35 lb in
                      Generator Bolts,32 N•m,24 lb ft
                      Generator/Starter Battery Positive Terminal,10 N•m,89 lb in
                      Intake Manifold Brace-to-Block (LL0),10 N•m,89 lb in
                      Intake Manifold Studs-to-Head,13 N•m,9.5 lb ft
                      Intake Manifold Support Bracket (L24)-to-Block and Intake,30 N•m,22 lb ft
                      Intake Manifold-to-Head (L24),30 N•m,22 lb ft
                      Intake Manifold-to-Head (LL0),13 N•m,9.5 lb ft
                      Knock Sensor,25 N•m,19 lb ft
                      Knuckle Attachment Bolts-to-Strut,200 N•m,148 lb ft
                      Lower Transaxle Bolts,130 N•m,96 lb ft
                      Oil Gallery Plug-to-Block,30 N•m,22 lb ft
                      Oil Level Indicator Tube-to-Block,30 N•m,22 lb ft
                      Oil Pan Drain Plug,37 N•m,27 lb ft
                      Oil Pan-to-Block,9 N•m,80 lb in
                      Oil Pickup Tube Bracket-to-Tie Plate,15 N•m,11 lb ft
                      Oil Pickup Tube-to-Block,15 N•m,11 lb ft
                      Oil Pressure Sending Unit,45 N•m,33 lb ft
                      Oil Pump Cover-to-Front Cover,11 N•m,8 lb ft
                      Oxygen Sensor,25 N•m,19 lb ft
                      Oxygen Sensor,45 N•m,33 lb ft
                      Power Steering Pump Brace-to-Block,30 N•m,22 lb ft
                      Power Steering Pump Bracket-to-Block,30 N•m,22 lb ft
                      Power Steering Pump-to-Bracket,30 N•m,22 lb ft
                      Rocker Arm Cover-to-Head (L24),30 N•m,22 lb ft
                      Rocker Arm Shaft-to-Head,25 N•m,19 lb ft
                      Spark Plug-to-Head,27 N•m,20 lb ft
                      Starter Motor-to-Block,37 N•m,27 lb ft
                      Starter Solenoid Terminal,5 N•m,44 lb in
                      Starter Support Bracket-to-Axle Shaft Bracket,30 N•m,22 lb ft
                      Steering Shaft U-Joint Bolt,47 N•m,35 lb ft
                      Stiffening Bracket-to-Engine/Transaxle,54 N•m,40 lb ft
                      Strut Bracket-to-Frame Nuts,50 N•m,37 lb ft
                      Support Bracket-to-Intake Manifold (LL0),10 N•m,89 lb in
                      Support Bracket-to-Intermediate Shaft Support Bracket (LL0),30 N•m,22 lb ft
                      Throttle Body-to-Air Intake Manifold (LL0),12 N•m,9 lb ft
                      Timing Chain Fixed Block-to-Head,26 N•m,19 lb ft
                      Timing Chain Fixed Guide-to-Block,26 N•m,19 lb ft
                      Timing Chain Pivot Guide-to-Head,26 N•m,19 lb ft
                      Timing Chain Tensioner-to-Block,19 N•m,168 lb in
                      Timing Chain Tensioner-to-Block,19 N•m,14 lb ft
                      Transaxle Dust Cover,10 N•m,89 lb in
                      Upper Engine Mount-to-Front Cover,50 N•m,37 lb ft
                      Upper Engine Mount-to-Front Rail Bracket,50 N•m,37 lb ft
                      Upper Mount-to-Frame Rail Bracket,50 N•m,37 lb ft
                      Upper Transaxle Bolts,90 N•m,66 lb ft
                      Water Pump Pulley-to-Water Pump Hub,25 N•m,19 lb ft
                      Water Pump-to-Block,30 N•m,22 lb ft
                      Wheel Nuts,140 N•m,103 lb ft
                      Wiring Harness (PCM Ground),10 N•m,89 lb in
                      Wiring Harness-to-Transaxle Case/Engine Block,25 N•m,18 lb ft
