About 3 weeks back after I changed my oil I started smelling that familiar oil burning smell and wrote it off as oil that could've splashed on the exhaust pipe when I took the filter off. But the smell never went away and after cleaning the back and underside of the engine and driving it about 100 miles in 3 days, I found fresh oil on the engine-transmission stiffener plate. I believe I have an oil leak either from the rear main seal or oil pan where it meets the transmission.
The really odd part is the oil level as indicated on the dipstick hasn't changed a bit and although the car now marks it's territory, the spots aren't big at all, maybe the size of dimes after leaving the car idling for 20 minutes just to see how much it would leak out.
The fluid levels that DO change are the ATF and coolant. I last added a very small amount of coolant to turn off the low level light back in November, and it came on again today and was just barely below the full line. The transmission appears to be gradually seeping fluid from the bottom of the case despite my best efforts to seal it up properly after I reassembled it when I had the diff pin welded. In almost 3 months of use, I've had to refill it with about half a quart of ATF.
Tomorrow I'm going to drive it up on ramps and drop the tie plate and flywheel inspection cover to see if I can pinpoint exactly where the leak is coming from.
Anyone know any quick fixes I can do in the mean time?
