Are you taking apart your MP2/MP3...look here if you need some help.
This is a sticky topic.
  • Are you taking apart your MP2/MP3...look here if you need some help.
    I made up some pics; thought it might help some of you out. Its the break down of the input and output shafts for you guys...and the names of the parts.
    The pics are about 2mb a peice...8megapixel camera...so they should blow up pretty large if you click the picture in the links.
    Input and output exploded:
    http://sixthsphere.com/storage2/imag...178gzezwx3.jpg
    Part names ...numbers correlate to picture above.
    Ouput shaft (driven gears)
    Picture:
    http://sixthsphere.com/storage2/view...ualn2j42wr.jpg
    Part Names, numbers correlate to pic above:
    http://sixthsphere.com/storage2/view...hpldq7eria.jpg
    Input Shaft ( drive gears)
    Picture:
    http://sixthsphere.com/storage2/view...vm29fo75zg.jpg
    Part names correlate to above pic:
    http://sixthsphere.com/storage2/view...jccjhc6acm.jpg
    Shift tower exploded...if you need it ( has selector bushings and things)
    http://sixthsphere.com/storage2/view...ctg0pi3840.jpg
    Names:
    http://sixthsphere.com/storage2/view...sk1qz7vtib.jpg
    Diff exploded (yes the pin has cme out LOL)
    pictre:
    http://sixthsphere.com/storage2/view...taz5rlbf5c.jpg
    Names of diff part:
    http://sixthsphere.com/storage2/view...spz2x95zif.jpg
    5th gear exploded.
    Picture:
    http://sixthsphere.com/storage2/view...ffvvllcdww.jpg
    picture with some helpful instructons:
    http://sixthsphere.com/storage2/view...d8l15muarv.jpg
    Blocker ring/spring inspection (those d-shaped rings make it hard to get in one gear and don't hold it in gear (its slipps out))
    http://sixthsphere.com/storage2/view...ai3re93baf.jpg
    Syncro hub and sleeve inspection and installion.
    http://sixthsphere.com/storage2/view...j8mb3xdocz.jpg
    Re: Are you taking apart your MP2/MP3...look here if you need some help.
    You are the man, thank you sir
    01' SL2
    Scat rods, hyper pistons, ported head, etc
    header, AEM WAI, MSD coil packs, walboro 255, etc
    5 speed swap
      I'm viewing with tapatalk and the only picture showing up is the first one. Do the other pictures still work?
      Im almost positive my input shaft seal/bearing assembly is leaking on the MP3 in the wagon. I actually have one laying around in my garage (no clue where it came from) the seal looks good. Curious if anyone has changed one. Looks like it's pressed on from the bell housing side?
      If this thread isn't to be cluttered up with questions let me know. I'll create a new post.
        Yes you have to split the case, drive it out from the inside.
        87 Fiero: Long term project.
        00 sl2: cheap DD pls no mods.
        01 sc2: high comp build round 2.
        08 lmm: aux tank, custom alum tonneau, aux oil cooler, aux filters, plow
        18 Acadia: Family hauler.
          Soo, not worth it.
            Clutch is slipping bad and I have a helical diff in that trans. I want to get it right so I can enjoy my new turbo with a newish clutch and not destroy it. It leaves a small puddle on the driveway after driving it. Needs to be fixed ASAP.
              Yeah if it soaked your clutch good chance the input seal / bearing ass it toast. It's pretty easy to change, just time.
                Support the center of the trans and use a press.
                2002 Saturn SL1 - RHD
