s-series alternator and starter
  • s-series alternator and starter
    anyone got any diagrams and/or pictures of an alternator and starter for an s-series? specifically, where the appropriate wires hook up on them and where the wires go to?
    danny and i are gonna try to get the car runnin tomorrow, so any help is appreciated.
    Haynes manual?
    STC New England FOUNDER
      Isn't his coupe a second gen? I would think they would be the same
        DOH. you're right, we both completely forgot about that. even if the block does have a window in it, the starter and alt is the same. [img]{SMILIES_PATH}/lol.gif[/img]
        and as for the hayne's manual...friggin worthless.
          You're welcome [img]{SMILIES_PATH}/lol.gif[/img]
            [quote="Silent Bob"]You're welcome :lol:
              I can help ya out real quick. I was stuck on the wiring for both myself after my engine swap. you will have 3 posts on the starter. a small one, a large one, and then another one that is wired to the starter housing. you only need to worry about the first two. the purple wire connector from the engine harness will go to the small post. and the wire from the alternater and the battery positive wire will go to the large post.
                thanks.
                well, we figured it out. just put danny's car up on jackstands and looked under it to make sure everything was hooked up right.
                got a call from danny this morning and she was runnin good.
