Subject
  • Subject
    It should only fit onto one of the ports, the other will be the wrong size.
    Low side will be the one that comes from the firewall.
    The high side goes to the condensor...it gets pressurized back to a liquid and needs to cool, so it goes to the condensor to cool off.
      One is the high side, and one is the low side. High side is the compressed side and the low side is the suction side. You shoud have about 30-35 psi on the low side when the a/c compressor is running.
        Follow them...the one that goes to the firewall is the low side.
          You don't need belt-driven A/C.... bypass that shit and you'll have 4x100 A/C like me! [img]{SMILIES_PATH}/cool.gif[/img]
          jfwy...
          If the compressor clutch isn't engaging... there is a A/C pressure sensor installed on low-pressure side by your fuse-box. You can't miss it... I don't remember the numbers correctly, but hit it with a multi-meter to check the resistance. Any good A/C specialty shop or dealership can tell you the specs it's supposed to be at.
            Wrong thread?
            Rattle noise or whine noise...whine, refill the PS...rattle, I dought the PS is making a rattle unless the assembly is loose.
              i should have know better than to click this thread.
