loosing faith
This topic is closed.
  • loosing faith
    My car hasnt been running very good lately and iv changed everything i could think of.
    New oil
    MMO soak
    new oxygen sensor
    new coil packs
    new egr
    new fuel filter
    new spark plugs
    new sprk plug wires
    new ground cables
    new serp. belt w/o A/C
    fuel ingection service
    new radiator
    new water reseviour
    I baught a scanner and got this
    (code 26) Quad driver output fault - The PCM deteccts an imprper voltage level on the circut that is connected to the Quad Driver Module
    but my SES light only comes on like once a week for a minute.
    all previous codes have been taken care with.
    OK here are my problems
    it does not pick up the way it should.
    When i floor it, it sounds like im flooring it but doesn feel like it at all. seams like i didnt give it any throttle but it does sound like it.
    Smoke at higher RPMS
    things i have noticed
    loud ticking coming from the cylinder head
    coolant disapears after long periods of time.
    runs really really rough in the morning
    trans. has a bad seal
    rotors squeak when they get hot
    what i think
    i think i need a new coolant cap for the missing coolant. Its never been changed and i read on haynes that it could not be keeping the proper PSI
    Im going to run a compression check maybe i need new piston rings, but would it run that bad??
    cylinder head idk why its ticking but i want to replace it soon
    rotors might be wrapped
    anyone want to take a wild guess what it can be?
    I will be running a comp. test today
    <br />tool:
    my guess - bad lifters.
    If you have a cat, that could be clogged also.
      nope no cat
      <br />tool:
        [img]{SMILIES_PATH}/thumbsup.gif[/img]
        had the same issue on a vw gti ran horrible...just had bad lifters
        Go turbo or don't go at all!
        <br />-NY
        <br />'94 Turbo SC2
          I was thinking the same thing.
            or, it could also be that one or a couple of the oil runners are clogged up and not allowing sufficient oil to reach the lifters thus causing the ticking noise?
              im thinking not enough oil because bad rings?
              <br />tool:
                Who fucking deleted my post?!
                I said, pour 1qt of trans fluid in your engine, and drive it for a day.
                The next day, drain and fill as normal.
                It's the same as engine flush.
                  ^im lovin this
                  if it was rings, it shouldnt effect the lifters
                  unless you dont check you oil
                    The ticking has got to be low oil, which is not good. How much of a bitch is it to change your piston rings?
                    2000 Saturn SC2 DD... RIP
                    2009 Ford Escape XLT 3.0L 4x4
                    2009 Yamaha FZ6
                        yeah might have some stuck lifters. but also, have you replaced the ects and the connector to it? i cant remember what exactly to look into with the quad driver though. its one thing i always see pop up but can never remember what exactly to look into.
                          quad driver= evap cannister purge solenoid and maybe egr solenoid?
                            i took replaced the egr
                            and whats the evap canister purge?
                            <br />tool:
                              little solenoid on the back of the engine block
                              and the code is for the egr solenoid not the egr itself
