Code 26??
  • Code 26??
    ok well iv been having a probelm...this past week iv got bew sparks and a new radiator. and now im getting SES with Code 26...i read wat the code means but im still lost. also sometimes wheni turn the ignition..nothing happens. wheni say nothing happens i mean NOTHING. no chime...no fuel pump...nothing..also i cant turn on my lights or anything ACC..i was thinging...a bad ground but so far i cant fine one.
    any suggestions?
    Quad driver fault.
    You need to take it to someone with a tech2 and have them do a quad driver test to see what circuit fails.
    Expect to pay around about 1/2hr check out to tell you what the circuit is and an hour check out if you want them to look into the probelm of the circiut.
    The stealership can do this.
