RPM Issue
  • RPM Issue
    http://www.youtube.com/watch?v=Ax5Fak9GrGk
    Just wondering what might be causing it to hang so high (and idle high in general). At first I was assuming it'd be to do with the fact that my clutch really needs to be replaced (I've known this for a while, but I don't have the time currently), but when Elvis looked at it this weekend he said he thought it was a vacuum leak.
    Does anyone have any ideas? I just wanted to ask a second opinion so I don't spend time trying to find a vacuum leak if it ends up being something else.
    i dont really see anything wrong. It hangs high for a bit when you press the clutch, okay , thats because of the idle air control valve.
    and it is idling at 1200 rpms, thats because your engine isnt fully warmed up yet
      That's supposed to happen? I guess I just don't remember it happening for that long. Hmm.
      It does idle high though (1100 even when warmed up) but that could be something else.
        adjust your throttle stop, just turn it out a little bit when the car is idling. stop when you like where it is
        97 sc1-- DOHC swap, P&amp;P head, race cams, AEM CAI, geo TB, eclipse 4-1 header, lsd, act clutch, fidanza FW<br /><br />na<br />14.9 @91mph<br />50 shot <br />[email protected]<br /><br />forged motor coming soon..<br /><br />vids<br />http://videos.streetfire.net/profile/bo ... dewayz.htm
          mine does the exact same thing, im not too worried about it. when its uber cold out it'll idle at 1200ish rpms and once fully warm it'll do its 900ish rpms. dont fret it, you'll be ok.
            For the record mine does this as well plus it surges up and down until it warms up...then it drops to about 900 rpms. It doesn't feel normal to me either as none of the other Saturns I've owned did this, but the ect & iac both look ok on the tech II so ......????
              Its rich on start up causing it to surge like that. If you have a safe, try taking some fuel out at idle and the lo-throttle postion.
                I don't.
                Is it "rich" like stock rich, or extra rich? Meaning like o2 sensor or something?
                  Just too much fuel... Mine did that when I put the bullfrog cams it. The MAP was reading more load, so it tryed to put more fuel in. It continued to go from 850-ish to 1200-1300 rpm at cold idle until the o2 was hot enough to read rich and pull fuel. Too much timeing an too mcuh fuel will do this. At cold start you will have more igntion advance and more fuel...both will taper off as the engine warms. If you ahve a safc, start the car cold, and just keep going down until it smoothes out. I had to go -25%at idle to compensate with the cams.
                    Do this:
                    http://www.sixthsphere.com/forum2/viewt ... ht=iac+mod
                    Originally posted by LowSL2
                    I just pushed the IAC all the way in to close the hole and uplugged the connector. Does the same thing.
                      WTF? Why did that thread get deleted?
