problems,problems,problems.....
  • problems,problems,problems.....
    my saturn 126k on it...if i put 87 octane in it and its cold, it doesnt want to crank so i have to keep peddling the gas peddle for it to crank then when it does crank it sounds like a mis fire and blows out a crap load of smoke....any answers? i dont wanna keep paying 2.67 for 93 becuz thats the only gas that it wont do it with [img]{SMILIES_PATH}/confused.gif[/img]
    is the smoke black? meaning its running extremely rich. is your check engine light on ? year/model?
    i'll be the first one to say it.
    ECTS
    check your engine coolant temperature sensor. if it has a plastic tip it is probably cracked and not reading right, therefore your engine is running extremely rich and flooding at startup.
      ECTS
      nope it is white smoke and when it does it all i smell is gas fumes no ses 96 sl2
        ECTS
        but after the sound of the misfire it runs fine...lol its a funny lil sad-turd
          white smoke is usually coolant leak isn't it?
          He who won't read has no advantage over he who cannot. Repeat after me: Investigate. Learn. Discover. Ignorance is not bliss.
            start off by checking the coolant sensor, if its never been replaced, there s a good chance it could be bad
              yes, usually (coolant/water in the exhaust).
              CSW Tuning or Facebook!
              - Stork
                where are you located at? maybe we can get someone to take a look at what's going on for you, kind of hard to diagnose things at times.
                it's somewhat normal to have white/grey smoke when starting cold from humidity in the exhaust system.
                I'd say ECTS and maybe TPS, but still hard to say. once it's running does it idle alright or is it all over the place? maybe the Crank Position Sensor too.
                  Check your coolant level is it low? White smoke usually means coolant getting into your cylinders somehow, blueish/black is oil burning. You may have a bad coolant sensor as stated above, quite possibly may even have a small break in your head gasket, or worse yet a warped head. If all else fails I used some Bars stop leak to cure my small head gasket problem till I can get my rebuilt motor into the car.
                    let see first try ects.
                    if there's oil in coolant or whatever then head gasket.
                      Hey dude, when you disconect the conector look real carefully for any corrosion on the terminal ends. If so replace it along with the cts. This sensor is the most critical sensor on the engine.
                        Far from true, but it is the most common failure and it will have a big effect on the way the car runs.
                          +1, the car will run with out a coolant sensor, the CPS is prolly the most critical sensor on the engine
                            the one that senses that theres a problem and shuts the car off and calls a tow truck instead of driving the car till it doesnt move sensor
                              ects.... Coolant temp = how it does enrichments and warmup enrichments for fuel [img]{SMILIES_PATH}/biggrin.gif[/img]
