Does the rear view mirror for a Saturn Vue withthe compass and temp options mount normally like all Saturn mirrors or is it different than usual and have any waire that need to be connected?
Saturn Vue Rear View Mirror mount
STC New England FOUNDER
[quote author=SL2clone]<br />Straight pipes sound like wet ass in a bathtub.[/quote]Tags: None
Originally posted by SupraCharged007yes, bolts right up, ask me how I know [img]{SMILIES_PATH}/smile.gif[/img]
but you will have to get the wire harness and wire it up. You also need the ambient air temp sensor and connector for the temp to work.
Is it hard at all? And I mean the installation you sick bastid!STC New England FOUNDER
lol. you dont HAVE to, but it won't work without haha. As far as the wires ....... two for the sensor, 12v ign, ground, and reverse lights which you can tap at the body inline connector behind the driver side kick panel (Thick green wire, a GUESS would say pin 24? but thats a stab in the dark)
so 5 wires in all, if you have the connectors for the mirror and the sensor, it should be cake. Let me know if you need any help, I could track down a diagram if you need one.
oh and btw, the connector for the sensor is the same as the CPS on the s series, if you happen to have a spare laying around or wanna get one from a JY, cause i think that connector is like $30 from Saturn, and thats with the employee discount.
Seems like a bigger pain in the butt than I thought. Thats a lot of cracker ass wires to run and connect. But we will see.STC New England FOUNDER
