I'm having a issue I jsut can't seem to figure out. The engine is a built 12:1 LLO with SDA cams (02 block, 01 head, 96 crank, forged rods/pistons), stock PCM for timing and fuel. Plugs are NKG's two steps colder with accel coils and SPS wires. Rockin the auto for now. Heres the issue: If I run anything less then 94 in it I get missing and detonation. It will surge and buck, especially under part throttle cruise. But when like this I throw no codes and my check service engine light will be off. If I put in 100+ (Usually run 1 gal toluene with 94 octane) I get almsot no misses/detonation, still some hessitation on launch but only because its idling low with the loppy cams. BUT I throw a "too rich" code. I've gone through and switched from a tank of 93 octane and had no codes then 94+toluene withthe code and back and forth again to make sure thats what it is. I have a emmissions test in three months I'd like to pass and they will fail me instantly if I have a engine code in the PCM. What could be causing this? I mean I dont want to run the lower gas because it runs horribley...I really thing its going to destroy something. Any ideas? Next step after a manu swap if its still doing this is to use the MegaSquirt for the injectors and hopefully lean it out but I don't see why its throwing a too rich when its definately running better. Any suggestions?
-Allan
-Allan
