any got a clue why my saturn is a pos
i swapped egr's last night and cleared the code with a scantool, start it up move it out of the way of the other car, (was moving then around ) then shut off the 97 walked to the 00 start it up and move it out of the way then i go to start the 97 it starts but idles at like 500-900rpms and stupid ruff then about 5 seconds later it dies.
try to start it up no go..
though ok maybe i dained the battery somehow. whipped out my volt meter nada.. saying i got 12.5volts in the battery, i checked the battery grounds they seemed fine and tight, it turns over but doenst catch, even when i tried to jump it with another car or when i tried to mannually start it in the drive way good old clutch in in gear roll back with ignition on, etc.. nothing..
i am gonna check fuel pressure and gonna see if i flooded it somehow gonna pull the plugs and look and gonna clear the camber after i pull the fuel pump fuse as well as look if any fuses blew..
fucking saturns... anyone esle good any good ideas?
