thrust bearing
  • thrust bearing
    just read this on qksl.com
    it was in the store section for the act 6-puck
    ACT 6-Puck: The only clutch worth
    getting. A pressure plate adapted
    from an SR20det Nissan motor
    because modified Saturn plates are
    simply crap. Clutchmasters/SPEC
    will ruin your thrust bearing.
    my question is if your act had wore down your pressure plate surface and your flywheel surface is it possiable that it is causing enough movement to still mess up a thrust bearing?
    anyone
      which one is a thrust bearing?
        it was the lack of oil pressure that killed that bearing. The ACT alone won't do that.
          that wasn't my question jay. i am asking if it can. wait till you see the bearing and the crank and then i will let you change your mind.
            even the stock clutch can wipe out the thrust bairing if you sit with the clutch in at every stop light
              yeah, but he doesn't do that.
              He had very low oil pressure, the red deth light was on every day.
                the red death light was only flickering on and off at idel. telling you jay with 600 miles wait till you see the wear.
                  mmmkay, then why did you post this thread...you seem to know the answer, and won't accept any other possibility. dick head.
                  I'll stop over tomorrow and have a look at it.
                    yeah it is toast becouse your the owner
                      answer to your question I have no idea but I ran a clutchmaster for over 30,000 miles and did'nt have any problems. Would still be running on it today if it would not have been ruined during the engine change
                      98&#39; SC-2 forged high compression on the bottle<br />84&#39; Z-28 building a 383. hoping for around 500 hp on pumped gas<br />91&#39; K1500 toy hauler but will be replaced again soon<br /><br />[img width=350 height=40]http://www.sixthsphere.com/storage/976/stc_banners-twiztidsc-2.jpg[/img]
                        Anyone remember way back, there was a guy that drilled a hole somewhere which put oil pressure right behind the thrust bearing?
                          That was mike ala boostedsl2. He and BC had a big discussion about it on TSN.
                            Wow, for some reason i dont remember it being mike. Anywho, how did it turn out?
                              yea, I thought that was Tom in NY? that did the trust bearing stuff
