I just got 93 sc2 and there is a sharp knocking noise coming from the engine.
I figured it was a stuck valve spring but I'm not sure. It has 150+k on it, it runs great except for the noise. It doesn't seem to be very consistent, it'll quite down and it'll skip a few beats some times too.
Also, I took off the wires to change the spark plugs and they were soaked in oil. Should i just change the cam cover gasket or change the cam cover itself? I have a 97 plastic cover as a possible replacement if necessary(are they interchangeable?).
