I'm going to put a SBC big brake kit on the wagon. I found out that a mid 90's midsized GM (like an Olds Cutlass) has a bigger piston on the master cylinder. (stock S has a 7/8 this one has a 1") Went to a junk yard and pulled one it bolts right up to a S brake booster and it has 4 ports on the correct side. I figure this is a direct bolt on. So my question is do you guys think it would be alright if I put the bigger master cylinder on FIRST and test it out for awhile to see if its an actual bolt on. Do you think I'll blow out all the seals on a stock S (has rear disc conversion) What I don't want to happen is put the SBC kit on and get a soft pedal and have to take it off. Right Billy? Oh yea I found a 2 port master cylinder that will work with you guys who have those.
Tim
Tim
