So ive been doing some searches and i came upon this " the phantom grip is pretty much universal" i was wondering how true this was. If i had a cavialer or a neon the same lsd would work in my saturn also?
Phantom Grip
I was under the impression that the phantom grip wasn't a true LSD...SaturnSeries.net Owner
Yeah, you pop the pin out, remove the plastic spacer around the gears, insert PG and put the pin back in. It's just like 2 pieces of metal with 4 springs in between them exerting force on the gears acting like a locker but still able to slip when cornering. At least that's how I understand it.
Here's mine.
Originally posted by scottyr94Yeah, you pop the pin out, remove the plastic spacer around the gears, insert PG and put the pin back in. It's just like 2 pieces of metal with 4 springs in between them exerting force on the gears acting like a locker but still able to slip when cornering. At least that's how I understand it.
[/img]
BTW it works great. I love it.
The instructions say to take it out...but that peice is in there for a reason. Its the friction barrier between the gear and the diff housing. If you look closly, it has small depressions in the plastic to allow fluid inbetween the gear and the plastic so help keep the gear lubed...with out the plastic, I can see bad things happening. That might be why some people have had so much material in their trans fluid when changing it every 10k miles.-6S Resident Mechanical Forensics member #001.
