If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You may have to register
before you can post: click the register link above to proceed. To start viewing messages,
select the forum that you want to visit from the selection below.
Welcome to Sixthsphere. Images and some forums are hidden to non registered members. Registration only takes a minute so please join in the community and share in the knowledge!
Does anyone happen to have a wiring diagram for the power door locks for the s-series? I need to know which wires coming off of the switch are lock and unlock.
Hit it was a volt meter when you throw the switch. If you have the right wire when you push in that direction of the switch, then you will get battery voltage.
