i think my speedometer is shot
  • i think my speedometer is shot
    i was driving home today and my speedometer startrs showing a rapid drop of speed and when im driving it lags and seems to take a while to show accurate spped is it possible to fix this or can i get an aftermarket digital or autometer speedometer outside of the dash?
    Replace the VSS (Vehicle Speed Sensor)
      where is d and price/ how hard is it to do
        Doubt it. Possible, I suppose.
        saturnparts.net very easy tod o.
          Your profile says 96 SL2...... Honestly, I would check the VSS first, if that's not it, go to the bonyard and pick up a guage cluster out of a 96 SL2 or SC2, and pop that in.
          IMO, I think it's the VSS. They're around $35, so I would do that first.
          But the guage clusters would run about the same depending on the bonyeard you go to........ I'd check here, call and ask for Chance
          Saturn Auto Salvage
            do you have aftermarket faces??? cause if the hole for the needle is to small then you gotta make it bigger thats what mine did,
            but it could be the VSS aslo
            Fucking Pringle bastards.
              Originally posted by brokenheadz2003
              do you have aftermarket faces??? cause if the hole for the needle is to small then you gotta make it bigger thats what mine did.
              [img]{SMILIES_PATH}/eusa_eh.gif[/img] Ya know, I REALLY didn't think of that one.
                it started working today i took the cluster out there was a loose wire back there i doubt it was the 1 i needed but it works now lol
                  That would be the problem child for ya.......
                  I wouldn't have guessed a loose wire, never had that problem.
                    ahh loose wirre, bad ground =non workin speedo
                      I told you it wasn't the VSS...it would probably read, or not at all...it wouldn't read sluggish.
                        loose wire on the vss would cause a funny read
                          Don't get so cocky..... I've seen the VSS on a vehicle have a short in it out of the box and give all kinds of jewish readings.... so it wouldn't have suprised me if it was his VSS, but it wasn't, so he's golden...... no greasy hands.
                            STFU N00b.
                            You don't know everyhting no matter how much you think you do.
                              STFU N00b.
                              bwhahahahah +1
