what's a good oil for my 97asc2. engine has roughly 55,000 miles on it. it's a swap from the last motor that died. it does burn oil. i think all saturns do. i was wondering if high mileage oil will work better than synthetic oil. and... if i swap to synthetic is it jus like changing my oil the regular way or do i have to flush it all out. thx
oil question.
I run 20W50 Valvoline durablend (synthetic/ conventional blend). Car has 200+ compression and 0-3% leak down in all cylinders. btw car has 162,000 miles on it.2002 Saturn SL1- 5 speed, basic, slow, and staying that way.
good call Heath.LSJ powered 1998 Chevy S-10 turbo
Running straight 20w-50 is not recommended on an engine designed for 5w-30. Good luck starting it if the temp drops a wee bit too much. The lifters will stay pumped up and you won't have any compression [img]{SMILIES_PATH}/lol.gif[/img]-6S Resident Mechanical Forensics member #001.
Originally posted by S.BretzRunning straight 20w-50 is not recommended on an engine designed for 5w-30. Good luck starting it if the temp drops a wee bit too much. The lifters will stay pumped up and you won't have any compression [img]{SMILIES_PATH}/lol.gif[/img]
I would recommend 10w30, and ialso use Durablend as well. If you want to spend more money and give your engine a "treat", I recommend Engine Restore 4 Cylinder formula, and Valvoline Full Synthetic Syn Power
Originally posted by HighEnd777I would recommend 10w30, and ialso use Durablend as well. If you want to spend more money and give your engine a "treat", I recommend Engine Restore 4 Cylinder formula, and Valvoline Full Synthetic Syn Power
I also add the Engine Restore as well and it has helped get the old engine down the road, especially with the nitrous treatment.
its a personal choice. any car ive had, i run a conventional in it a few times and change it more often the needed. then i switch to full synthetic. i will run mobil 1, penzoil, quaker state, and my favorite royal purple. i also typically run 10w30 in summer and 5w30 in winter. 01+ vehicles i have put in 5w20. now turbo, id run a 10w40/15w40.Ian---The Fat Ass
Originally posted by saturnspeed_12its a personal choice. any car ive had, i run a conventional in it a few times and change it more often the needed. then i switch to full synthetic. i will run mobil 1, penzoil, quaker state, and my favorite royal purple. i also typically run 10w30 in summer and 5w30 in winter. 01+ vehicles i have put in 5w20. now turbo, id run a 10w40/15w40.
you forgot the slash there vin [img]{SMILIES_PATH}/lol.gif[/img]
yes, tis be a winter wonderland up here sometimes. can i live with you when that magical stuff falls?Ian---The Fat Ass
Ya'll say ya'll in Michig? I thought it was a south thing. Anywho, my '94 engine has 314,590 miles on it. Yeah, she smokes a little bit when you crank her up, but manage to take alot of ricers down. My 2 cents is this: I just recently switched to higher mileage engine oil and I can't say enough about it. Oil burnoff has been cut in half and the old dohc seems to run a bit quieter and smoother. I have never used any oil treatments like STP or RESTORE so I cannot comment.
