Alright. So i just got a 97 SW2 as a DD. Everything was fine til yesterday when the low coolant light came on for about 2 minutes then turned off. I stopped at the first gas station to check it out. With the temp guage at 1/4, i started slowly unscrewing the cap to the resevour. I heard a little "psss" and that was it. Checked the fluid level and it was maybe an 1/8th inch under the fill line. So i filled it up and went on my merry way. Well it did it to me again tonight on the way home. Except this time the water level was down quite a bit. There is a white resedue under the resevour and down the side of the frame well but its never wet. The coolant is brand new and bright green, but there is a very small amount of a greenish, almost gel substance, at the top of the resevour. Im thinking its the resevour cap, and im really hoping its not the damn HG. What do you guys think?
Crouching wagon, missing coolant......
Green works better...I have seen fewer water pumps leak with the green stuff. Maybe is a conicendence...or maybe not.-6S Resident Mechanical Forensics member #001.
Originally posted by sl2fastwhat about the whole dex cool shit whats up with that, in the manual it says use only taht or is taht just a scare tactic thingy bitch-6S Resident Mechanical Forensics member #001.
Originally posted by Jeremy97scIf its not the radiator or cap, then your overflow tank is leaking. Ive seen that happen.
FYI: You should have orange coolant, not green if its a 97.sigpic-VOLVO 745T 175K MBC ...
Originally posted by therealm0rh0usOriginally posted by Jeremy97scIf its not the radiator or cap, then your overflow tank is leaking. Ive seen that happen.
FYI: You should have orange coolant, not green if its a 97.SaturnSeries.net Owner
Originally posted by S.BretzOriginally posted by sl2fastwhat about the whole dex cool shit whats up with that, in the manual it says use only taht or is taht just a scare tactic thingy bitch
Originally posted by project92SC2Originally posted by S.BretzOriginally posted by sl2fastwhat about the whole dex cool shit whats up with that, in the manual it says use only taht or is taht just a scare tactic thingy bitch
