Danny, check for a vacumm leak. I would suspect a leak for a high ilde.
Also, I woud check the CTS, at colder temps, the engine lets the IAC open more to let in more air, but the idle will be lower then if the IAC is in the same position wen the engine is hot.... you can try swapping the IAT and CTS around to see if that makes a difference. If it does, then you have a bad sensor. This may explain why its also running rich.
If i remeber correctly, you have a 97...they have an adjustble regulator, and vac hose that runs to the regulator. If that hose is leaking, then the fuel pressure will go up and the idle will go up, and the car will run rich.
But firts check for vacuum leaks. When its idleing high, try pulling over and spraying throttle body cleaner around spots tha might be leaking....t-b, vac lines, brake booster line, the intake manifold to head. If you hear a change in idle then you found it.
Also, a cheap easy thing to eliminate is the PCV valve. Its aobut $4.50-$5 at the dealer. Also inspect the PCV hose as they sometimes crack.
