bought a 99 sl2 about a week ago, when i put the car in drive and start to drive forward there is a sort of clunk noise sounds like its behind my pedal. it only happens once, when i first put the car in drive, any ideas?
hey
Ahhh, that's normal. Its the slop in the drive line tigthening up. If you go to reverse and back to drive again, the noise should repeat.-6S Resident Mechanical Forensics member #001.
Originally posted by HighEnd777does the whole car kind of buck at first? Whe nI from D straight into R it jerks kind of, but if I slide through D. N, and then R its fine.
You have to STOP first before you shift from D to R, and vise-versa.
Originally posted by project93SC2Originally posted by HighEnd777does the whole car kind of buck at first? Whe nI from D straight into R it jerks kind of, but if I slide through D. N, and then R its fine.
IDK could be mounts, or the brake cailpers/rotors loading up to keep the car from moving...or just the slop it the drive train tighening up.-6S Resident Mechanical Forensics member #001.
If there is anything wrong it would be the motor mounts. But like Sma said it may be the slack tightening up, my gf's car does it from time to time.2002 Saturn SL1- 5 speed, basic, slow, and staying that way.
Is your car abs equipped? On my car, you hear a marble rolling sound, then a high pitched beep, and it only happens once every time i drive it. Cant recreate it even when going backwards then forwards. That sound is the ABS system running a self check. Try stepping on the brake in the middle of the self check and see what happens. It'll be VERY interesting.
