brake disc replacement
  • brake disc replacement
    could someone post a how-to for swapping brake discs on a redline? i'm installing springs and rotating tires tomorrow, and want to put on my new discs too, but i'm not sure i know enough about it to try it blind.
    -Kevin<br /><br />&quot;Ha ha HA! Mine is an evil laugh...now die!&quot;<br /><br />
    if you have disks allready it is real easy just take one bolt out and rotate.
      there are two bolts on the back side of the calipers that come out and then you just swap the discs.... the only tricky thing is that the back calipers just turn into recompress them...
