ok so I have a differential with the diff pin welded. So here is the problem I had nice and stored in my closet, but somehow it found it's way outside (fucking stepdad) so it got wet and now there is rust on it. How bad is that and can the rust be removed? N is the differential still good?
Diff pin
and itll clean it up too after you soak it wipe it w/ a cleanish rag and the rust should come right off then you can install it in your trans and soak it again as your drivingsigpic-VOLVO 745T 175K MBC ...
