i click on the burn to ecu botton and it sais it can not connect to device or some shit like that.the ms is getting good power.so what could be the deal here?
megasquirt issue
and check if you have something blocking the port like HotSync for palms or something like that.
-Allan.-Allan
Did you ocnfigure megatune to read the proper version of Megasquirt and MS imbedded code....I'm betting not.-6S Resident Mechanical Forensics member #001.
Did you follow the instuctions? There was alot of stuff I missed can caused the same issues. You have to configure MT to you version of MS.
What version of MS and code are you trying to use?-6S Resident Mechanical Forensics member #001.
ms1 v2.2.are talking about the section where you can select ms1 or ms2 and a bunch of other stuff.if so i have it set for the ms1.code? not sure what you mean by code.please tell me.i still laugh when someone says performance and saturn in the same sentence.
Well, whatever problem you have with the v2.2 will still be there with the v3.0 if youdon't have MT set to read you shit.
You will have to go into the software and rename one of the files so that MT knows what version of MS you are using. You aslo have to change the speed of the com port. If its ms1 it should be 9600 baud, if its a MS2 it should be 115200 baud (or something like that).
If the baud rate in MT is not right, then they can't talk.-6S Resident Mechanical Forensics member #001.
You need to set the ver of megatune you need to run inside the megatune configurator. Are you running the MS1 firmware or Extra software? What ver os megatune are you running? How are you connected to the MS by DB9 serial or do you have a USB adaptor?
man...did you even read the megamanual? (not you Crispel)...anthony?
It helps ALOT....I thought my sizzel was all fucked and not working...turns out I was not working IT right...but I'm good at that. That's why I;m in trouble with Melissa most of the time. [img]{SMILIES_PATH}/lol.gif[/img]-6S Resident Mechanical Forensics member #001.
