My sun roof wont open. It sounds like it wants to open when you push the botton but it doesnt. What do you guys think could be wrong with it.
sunroof
yeah one of the cars at the junk yard near me has a sticker on the bumper that says i heart my twincam and also has the sunroof sealed with calk lol[quote author="triman54 on s2ki.com, May 16 2008, 04:02 PM"] A Saturn is like a box of chocolates... [/quote]<br /><br />2007 Central Florida Region East Coast Champion STS<br />2007 CFR West Coast Champion STS<br /><br />
the sliders are either broken or jammed. they do that alot since they use cheap sliders. you will need a new sunroof sorry2007 chevy classic 2500hd 4x4 duramax
Originally posted by sl2racerthe sliders are either broken or jammed. they do that alot since they use cheap sliders. you will need a new sunroof sorryIan---The Fat Ass
Originally posted by saturnspeed_12Originally posted by sl2racerthe sliders are either broken or jammed. they do that alot since they use cheap sliders. you will need a new sunroof sorrysigpic
There are a few problems with the SATURN sunroof...
One, it's mostly plastic. You can get a better one from http://www.sunroofdoctor.com
Two, the drain plus are retarded. Fix those fast. It's a pain, but worth it. The plugs at the end only have 3 tiny slits in them to let water out. Either someone was high on crack when they designed that, or wanted it to eventually fail so you would come in and get all new shit.
Third, the drive motor was designed by a 3 year old. The gear that drives the arm cables does not sit in well, and will eventually wear down, causing the gear to really not make adaquate contact with the gear to move the cables. This is what causes the constant clicking (unless you broke an arm or cable, in which that will be the problem). I am currently trying to find a cheap fix for this. I need a broken motor though to work with, cause I don't feel like taking mine out again. I managed to fiddle with it before and get it so it didn't click, but eventually that didn't last long. The gear on the motor needs to be about 1/8 of an inch larger or something like that.STC New England FOUNDER
