I went to go install some new plug wires and pulled the #1 plug wire boot out along with a crap load of oil. There's so much pooled in there you cant even see the plug! There's also some spots where oil is seeping out of the valve cover.
Does this mean a bad plug seal/valve cover gasket or a much larger issue at hand? The car runs just fine...no idling issues and isnt misfiring at all...so the plug must be firing ok even with all that oil.
