HELPPPPPPPPPPPPP!!!!!!!!!!!!!!!!!!!!
  • HELPPPPPPPPPPPPP!!!!!!!!!!!!!!!!!!!!
    my cooling fan died yesterday
    went to discount for a replacement.. they give me a 10 inch fan
    that flows 500 cfm
    is that close to the original one or will i have to install a second one
    PLEASE FEEDBACK IS NEEDED... FAST
    Bigger. Better. Keebler
    <br />Sometimes when I reflect back on all the beer I drink I feel ashamed. Then I look into the glass and think about the workers in the brewery and all of their hopes and dreams. If I didn't drink this beer, they might be out of work and their dreams would be shattered. Then I say to myself, "It is better that I drink this beer and let their dreams come true than be selfish and worry about my liver."
    I have a stock one you can have for like $10 and shipping [img]{SMILIES_PATH}/biggrin.gif[/img]
      do you think the 10 inch will work till i get a different one
        or do i put a second 10 inch one on the car
          i dont know the specs on the stock fan but if the one u have on there leaves enoth room for a second one and its only 10 bucks and u have to drive it alot id be on the safe side and put a second one on there, its not gonna hurt anything, it can only help
            OK will it work or will it not.... Am i in a world of trouble or what...
              dude all you need is the fan motor.
                how do i change the fan motor
                  it unbolts
                    do you know how many cfm the oem one flows
                      nope.
                        OK, look, if you've already unpacked the part, chances are, they won't take it back... why.... because they're asses.
                        So, go to the boneyard, or hookup with a buddy on here for a stock fan, and wire that second one in with it. Also, get a Chilton's manual..... it will make the job SO much easier. Use the table of contents first, and the index, don't just scan through it like I used to, you'll be looking forever.
                        The wiring is simple. The wiring harness for the fan, is running through the same path as your A/C Harness. Follow that back.
                        BEFORE YOU BUY A NEW REPLACEMENT FAN..... TAKE THE OLD FAN OUT, AND HOP IT ON THE BATTERY TO CHECK TO SEE IF IT IS SERVICEABLE...(IN WORKING ORDER...) A lotta times, it's the CTS, (coolant temp sensor) or the ECU that went out of whack, and this is not just on Saturns either.
                          or the fuse
                            The stock unit moves a but load....something close to 2500cfm.
                              oh damn
                              i am not coming close
                              I am going to by the replacement motor and then move the 10 inch infront of the evaporator... as a pusher
