i recently have noticed two things my car does that is abnormal. one the temp guage is sittting about 1/8th higher then normal. when going to work it usually only reaches the 1/4 mark. but now it sits in between the 1/4 and 1/2 mark. and it take longer for the engine to cool. could this be the coolant needing to be changed or a sensor?
also the ses lite comes on intermitenly. usually when driving at the same speed. with no change in change in rpms. if im accelerating or decelerating it goes off till the car has a steady rpm position and speed. any pointers or idaes?
