So you might know that I got my car running recently.
On the jackstands, it started and idled nicely.
Now, it starts fine and idles fine when cold.
Once the car heats up to temp, it bounces from stoich to lean, like 16:1. It runs ok though, loss of power is evident though. Once I come to a stop, the idle surges and it occasionally dies. It will go from normal idle speed down to almost stalling, when this happens, the AFR goes from stoich to lean again.
Background info:
New ECTS, good o2 sensor etc...
The gas in the car has sat since July. Do you think some fresh gas and some gas drier would help? What about the fuel filter? Its obviously fuel related, if it were spark related, the car would be super rich no?
TIA
Background info:
TIA
