How HARD is it to replace? I did a compression test and CLT in class the other day (Compression was around 205, and CLT had less than 7% on all cylinders WOOT! 154,500 on her too.) Well while doing so I was was listening for sounds just as I heard and well the timing chain is making noise. I took the long screwdriver gimmick and listened. My insrtuctor said it needed to be changed (I agree as well). What you guys think? Do I need to drop the engine or what?
Timing chain
Originally posted by Schizzo97SC2I did Frank's in the car, wasn't all that hard actually. biggest bitch was the power steering assembly bolts. other than that I think you can handle it in the car.
Sumtimes you gotta jack the engine up and down to reach certain bolts, but it can be done
Good Luck[img width=600 height=150]http://www.sixthsphere.com/storage2/images/wejag665buljx09mu77e.jpg[/img]<br />99SL2 w/97SC2M Engine/Trans Swap, CAI, 2.25 Custom Exhaust
Originally posted by ProjectSW1Originally posted by Schizzo97SC2I did Frank's in the car, wasn't all that hard actually. biggest bitch was the power steering assembly bolts. other than that I think you can handle it in the car.
Good Luck
and let me tell you, power steering bracket bolts hold everything on that car lol
Originally posted by HighEnd777biggest pain to me, was sliding the timing assembly cover in the space between the engine at the chassis, by where the top mount is. That was hard because it kept banging and shit.[img width=600 height=150]http://www.sixthsphere.com/storage2/images/wejag665buljx09mu77e.jpg[/img]<br />99SL2 w/97SC2M Engine/Trans Swap, CAI, 2.25 Custom Exhaust
I can't add much except to agree with everybody. I have done it while in the car and using a floorjack to raise/lower the engine (while the TAM is off) makes it ALOT easier to get to all of the related bolts and remove the timing chain cover.
Power steering assembly is alot of fun lol. Also, don't forget when you remove all the outer timing cover bolts and the four that connect to the oil pan, that there is one or two (depending on your year) in the center of the cover, alot of people forget about them and start trying to pry the cover off. Don't forget them!!
Having the car on a lift makes it real nice but if you at least have a floor jack to move the engine, it's not too hard.
baby shit,periodMAKE EM FAST,BREAK EM FAST
<br />93 saturn sc2 <daily driver/weekend warrior>
<br />http://www.cardomain.com/id/sbforever420
<br />95 saturn sc2 <one of the cleanest 95sc2's>
<br />http://www.cardomain.com/memberpage/835977
Originally posted by HighEnd777Originally posted by N20SATURNbaby shit,period2015 Ford Mustang - DD
yeah that s pretty funny right there
but seriously
i just finished an overhaul on a 95 sw2
the timing component part was pretty easy
i had the car jacked up so the tires were about 6" off the ground and if you use a prybar under the lower engine mount you can cram a 2" x 2" block of wood in there and it holds the engine in a perfect spot where you dont need to move it untill you put the tam back insigpic-VOLVO 745T 175K MBC ...
Originally posted by HighEnd777Originally posted by N20SATURNbaby shit,periodMAKE EM FAST,BREAK EM FAST
