installing exhaust manifold
  • installing exhaust manifold
    Since Omars engine is done, Ima take his exhaust manifold without the precat. itll be better than mine... i hope.
    anyways, we were talkin and he said we should be able to do it ourselves.
    my question is, do i need to have the downpipe welded to my exhaust (stock at the moment) or can i buy some kind of clamps to clamp it together?
    if i have to weld, where is a good welding place in orlando that is open past 5 on saturdays ( i work til then).
    if i can clamp it, where can i get a clamp and what kind of specs would i need to know to get the correct one?
    Jason
    you're going to need to clamp it
    not sure on any place open at that time on saturdays
    you might need to go early to get it welded up during a weekday
      Why not just use Omar's stock shit and bolt it to the stock cat flange under the car. You will need the manifold and the down pipe. There should be no need to mod anything under the car....unless Omar had is stock flange fucked with.
        he'd still need the downpipe welded up to the cat though Sam
          im gettin the manifold and downpipe from omar. i just wanted to konw if itll clamp or if i need it welded. vinny is insisting on welding, so i guess thtas whatll need to be done.
          Jason
