oil leak
  • oil leak
    I cant find it I have a leak any one know of a easy way of finding it Ive looked every were but the right place lol
    can you give us a general area?
    a particular side of the engine maybe?
    We really can't help you based on the info you've already provided
    this may sound really fuckin dumb, but did you check the oil pan plug?
    I'm in no way insulting your intelligence, i'm actually guilty of it myself... lol
      back side an right side its not the head its not the intake it only does it when driven because I let it set an run for an hour an it doesnt leak
        clean everything real good and use uv dye in the oil then look at it w/ a blacklight and it should jump rite out and bite you
          thanks for the help I will do that maybe I wont have to pull it completely apart
            Oil sensor... passenger side of the block bottom / back side...
            umm... could be the timing chain cover where it bolts to the oil pan
            thats all I can think of at the moment
            have you recently taken your engine apart?
              cool will check it out really thanks for the help its driving me nutz
                put cardboard under your car overnight, and if you have any spots, follow them up to get a better idea of the leak area.
                  why didn't I post that? [img]{SMILIES_PATH}/lol.gif[/img]
                  sumtimes the correct answer is the OBVIOUS answer...
                    lol ok I will do thanks again for all the help
                      if its all over your aaxle, check your oil pan gasket
                        yeah you have to clean it the area so you can tell where its leaking. if it seems to be up on the intake and leaked down, its your valve cover.
                          ok I havent been ableto find where can I find that uv dye at
                            i get it from local parts places
                            in ny of course
                              I found it at napa no one else sell it ....
