copper head gasket?
  • copper head gasket?
    is the torque specs the same as stock when using a copper heade gasket?
    or will it need a little extra or less torque?
    i still laugh when someone says performance and saturn in the same sentence.
    Te torque specs are the same. If you have aftermarket head bolts/studs, then torque to the recomended values that are listedwith the bolts/studs.
