strut rattle?
  • strut rattle?
    when i hit a bump the right front makes a clattering kinda rattle.is it the strut or the brakes?
    i still laugh when someone says performance and saturn in the same sentence.
    its a saturn it will never be quiet...
    umm mine did the same when i hit bumps... its prolly your top mount where the bearing is... thats what happend on teh SL
      well, i doubt its the brakes, unless someone messed with them and they are loose. strut mount possibly. craddle not tight (shouldnt be a problem unless you have dropped it and didnt get it tight), engine mount busted, tie rod, steering rack loose. it can be quite a few things.
        Re: strut rattle?
        I woudl say its the strut...
        mine is doing it too... but its the back one
          mine has a sound on the right side also, started once i put my intrax springs in, sounds like the spring coils hitting eachother. i just said screw it ill live with it, its become my friend!
            ball joint.
              i have no input except take the wheel off and check it out
              my car s makin some noise in that same area ill probably have it on the lift tommorrooooowwww and ill let you know why my noise is there
                well all 4 struts have been bad sense i bought the car [img]{SMILIES_PATH}/biggrin.gif[/img] but it never made any noise untill this weekend.ill check it out tomorrow.
                Loading...
