which injectors
  • which injectors
    what injectors should i buy.i know there low impedance(91-95) but i seen a lot of injectors that are a X number of ohm's.can someone point me in the right direction as to what kind or where to get injectors.thanks in advance [img]{SMILIES_PATH}/wink.gif[/img]
    i still laugh when someone says performance and saturn in the same sentence.
    just any peak and hold, low impedance, injectors. stay away from anything 11-18. i think most low impedance are like 4-6 or something.
    what are the plans that you need new injectors? going to run a fuel controller? do you already know what size your going?
      im getting 32lb injectors most likely.im getting fuel control later on because im not using the injectors right now.
        the low should be 2-5 ohms.
        My accel 30's where high resistance (12-15ohm) They will work fine in the OBD1. If you are looking for 32 lows, get 34 highs.Its ok to to use the highs on the low imp driver,...but its not ok to use the low imp injectors on the high imp driver.
          sweet deal sam.thanks
