AC and Cruise Problem HELP!
  • AC and Cruise Problem HELP!
    Hello, last summer my 1996 saturn SL2 air-conditioner completely quit working. The next day it was back working to normal. It did that off and on for a while.
    Now it will not come on at all, and the funny thing is whenever it goes off the cruise control also quits working. So now I have no heater/airconditioner or cruise control.
    This can't be a fuse problem or it would not work sometimes and others. I have also check all the fuses and did not find any bad. What could cause problems in both the cruise and the air and heat? It will not even blow air.
    do you get anything to light up on the hvac controls? say like recirculation light, anything? maybe everything can be linked to a ground. but i do know, not certain its your case, but on some fords when the ignition is going bad, you can lose your wipers and hvac controls. i mean possibly ignition switch, but not certain.
      No I can't get even the lights to come on.
        Obiously this is some sort of electrical problem.
        Are there any other lights not working besides the Recirdulating Light?
          Is the blower motor not coming on, or is the a/c compressor not coming on, or both?
