I have a 2001 SC2 and put a msd sytem with the coils,coil interface and msd dis 2. I am having problems with the SES light comming on. I've adjusted the MSD-DIS2 by turning the white switches on the side of the DIS and got results ranging from the car not starting to a rev limit of 3k.When I get the car to run corect the SES light comes on. How do you guys with the MSD set up have the switches set up?
msd issues
you need a cam sync generator and wrap it around plug wires # 4.
here's a link.
http://www.msdignition.com/sci_17.htm
always rememebr.... SES light = car runing right
SES light off, watch out...
but yea... I installed MSD iungnition coils on my SL and had rpoblem with it, next morn i cantact MSD and got it fixed up.... i forget how i got it tho
but hey best of luck to ya
how has the car been running? seem to be running a bit rich, lean, anything out of the ordinary?Ian---The Fat Ass
Originally posted by ElvisCyou need a cam sync generator and wrap it around plug wires # 4.
here's a ]http://www.msdignition.com/sci_17.htm[/url]
Originally posted by dream36realmsWhat exactly does it do for a NA saturn? I could see adding spark but what about the rest it claims?
Originally posted by saturnspeed_12how has the car been running? seem to be running a bit rich, lean, anything out of the ordinary?
Originally posted by Plastic FuryDid he purchase the cam sync generator??? I don't know for sure because with my MSD Dis-2 and the first gen I did not need it but I am pretty sure he will.
I also have the interface moduals and the MSD coilpacks and have never had a single problem since day one.James E<br /><br />No i'm not new, Just been M.I.A for a while.
so nevada has that crazy inspection setup as well?
what year is your car and what code is setting and is it a hard fault?sigpic-VOLVO 745T 175K MBC ...
Originally posted by therealm0rh0usso nevada has that crazy inspection setup as well?
what year is your car and what code is setting and is it a hard fault?James E<br /><br />No i'm not new, Just been M.I.A for a while.
Originally posted by OpusguyOriginally posted by therealm0rh0usso nevada has that crazy inspection setup as well?
** From MSD's website--- The Cam Sync Generator was designed primarily for Saturn applications with a DIS-2 installed. It can also be used for other waste spark applications.
After installing an MSD Dis ignition control on some waste spark ignition systes, the ECM of the vehicle may not be able to recieve a cam sync signal. The Cam Sync Generator will produce a cam sync signal after start up for the factory ECM. This is done by detecting a cylinder that is under compression by it's signal wire wich is wrapped around the designated spark plug wire. On Saturn applications the number four spark plug wire is used for the cam sync.
Originally posted by Schizzo97SC2I don't know if that will work in this case ElvisOriginally posted by Plastic FuryOriginally posted by OpusguyOriginally posted by therealm0rh0usso nevada has that crazy inspection setup as well?
