ok so yesterday i was washing my car. i pushed it out of the garage since i didnt want to start it to back up a whole 10 feet. after i washed it, didnt wash engine, i go to start it and it started and sputtered then died. a cloud of semi black smoke came out. i go to start again and it takes a bit but it sputters then dies. i try once again and floor the gas and it took about 8 secs and sputtered to life. i let off throttle and it dies off and i bounce the gas a few times to revive it. i had to rev it for about a minute to two before i could get out and check under the hood for anything. i checked exhaust and noticed misfires. looked under the hood and was obivous that it was misfiring by how it was shaking. no cel was on. i took it around the drive here and it ran fine. day before ran fine. didnt stall it or nothing. it was flooded, thats all i know. something caused it to either not fire or dump fuel in. im thinking ects or crank sensor.
only thing ive noticed, when i met up with molly, i had the car running for a long time looked at temp gauge and saw it at 1/4. it should have been easily near 1/2. started to wonder if the ects has gone bad again, but car run fine entire way home.
